What size Alum. Solid Roller Strokers?
Restricted User
I am thinking of doing a solid roller stroker, I want to utilize the Aluminum block, and most likely a solid roller setup, I can deal with valve adjustment. I would like to hit 500rwhp, and be able to spray some large shots-300+ using a DP setup and Progressively timed.
TIA, Charlie.
TIA, Charlie.
Just about any sponser here that builds engines can get you those #'s with a hydraulic roller. IMO, most could get you close to 600 or better if your willing to go big cam and compression with a solid roller.Anyways its all tuning and chassis at that point. Good luck!
