6.0 Installment On T/a
Old Jan 30, 2008 | 09:26 AM
davidsupersport's Avatar
Default 6.0 Installment On T/a
I need some help on installing a 6.0 on my t/a . Will I need help with the block/motor mounts and will that motor mount up to my transmission without any fabrication. I know all of my electrical parts will work like alternator and everything else .Only potential problem will be to drop the motor in PLEASE SOME ONE HELP ME..........
Old Jan 30, 2008 | 09:30 AM
sdimess84's Avatar
It should bolt right in. Tranny in all. Should be pretty basic.
Old Jan 30, 2008 | 09:38 AM
chromeplated500's Avatar
When I did mine I used the mounts off the LS1, and all the accesories off the LS1. do you have an '03 and newer 6.0? because the older ones have a longer crank which to my knowledge won't work.
and you're gonna want to drill and tap one of the alternator mount holes into the block..... because its not there to start with.
