QUESTION: can you drop a motor using a 4-post lift?
I know how you do it with a 2-post lift, but what I was thinking is this (some steps are left out, just a general procedure):
1. Drive the car on the lift, raise the front end and put jackstands under the front framerails so you can remove the wheels.
2. Disconnect the lower a-arms from the k member, then unbolt the necessary stuff up in the engine bay.
3. Put the lift down and put supports under the k member.
4. Unbolt the k member from the chasis and lift the car in the air.
The whole issue is that the front wheels / a-arms would be blocked by the lift ramps. I beleive the ramps are ~38" apart, which should be enough to drop the k member through.
If I can't use a four post, it's okay, my brother in law has a two post at his house, but I'd rather not ask that favor if I didn't have to. I wouldn't want to tie up his lift because he uses it to make money on the side.
Thanks.
Again, about the only think I can think of that will be restricted using the four post is pulling the motor.
Also, my garage doesn't have any posts in the middle, so I can pull the car in, put it on the lift, and then move the car towards the center to work on it, can't do that with a two post. Plus a two post takes up moe space that a four post. It's only a 20x20 garage, and the two post is wider than the four.
http://www.gregsmithequipment.com/Pr...PROJACK%2D3500
Frank
I'm either going with the pro-park 7 or 8, not sure yet, but I'm also getting the jack as well from Greg Smith Equipment. They are in Delaware which is an hour drive from my house. Nice thing is there is no sales tax in Delaware.
Frank
