What heads?
Old Jan 31, 2008 | 01:04 PM
silverbullitLS1's Avatar
Default What heads?
Im planning on buying some heads pretty soon and wanted to know which ones would be the best for a TSP TORQUER V3 cam and the other mods below?
Old Jan 31, 2008 | 01:46 PM
RedRallyeZ's Avatar
i bought the PRC 2.5 5.3 liter heads with that cam. ill give you numbers in about a month...
Old Jan 31, 2008 | 04:03 PM
LS698ta's Avatar
i got the patriot 243 castings stage 2!!
Old Jan 31, 2008 | 08:42 PM
Gunnar@Patriot's Avatar
We can do you set of our CNC ported 243 heads with Ferrea 2.02"/1.57" valves, our Famous Patriot Gold springs, ti retainers, all the goodies for $1295.00 per pair. Check them out our new website or give us a call!
Old Jan 31, 2008 | 08:55 PM
Shawn @ VA Speed's Avatar
afr 205,the small runners will work great with that cam
Old Feb 1, 2008 | 04:59 PM
Bill Bowling's Avatar
I am going with ported Dart 205's with my torquer 1 cam.
Bill
Old Feb 2, 2008 | 07:35 AM
Johny GTO's Avatar
which heads will give you the most torque?
anyone care to give 2 or 3 head choies throughout the price rane ($800 - $2400) that prodiuce the sexiest results
Old Feb 2, 2008 | 12:02 PM
SOMbitch's Avatar
AFR or Trick Flow are what I am leaning towards. Both have very good low/mid lift #'s that will produce good torque as well as topend. TEA does a great CNC port job on the TFS from what I have read. You can't go wrong on either of these. ETP is stong too. These are the big three IMHO You are at the topend of your budget though.
Old Feb 2, 2008 | 12:06 PM
SweeTbone's Avatar
I went with those heads and I am definitely satisfied with the results. Numbers in sig.
Old Feb 2, 2008 | 03:35 PM
Johny GTO's Avatar
what is the difference between the 215cc and 225cc Trickflow heads?? Is one for the LS1 and the other LS2?? Or is it a matter of torque versus hp?
Old Feb 2, 2008 | 07:34 PM
m8w6r77's Avatar
the size of the intake runners.
gunnar- what is the size cc is the combustion chamber on those heads for 1295.00
Old Feb 2, 2008 | 09:09 PM
HEMIETR's Avatar
TFS has a new "as cast" head that is supposed to real good. If $$ is not an issue, ETP TFS and AFR thats it.
