You think this will make 600+rwhp?
Old Jul 10, 2003 | 02:07 AM
TNT_Z's Avatar
Default You think this will make 600+rwhp?
Ok guys I have a 2002 automatic Z-28 with every bolt on except crank pulley, a 3200 vigilante converter, CNC/hand polished and ported heads and now am on my 4th cam. History...with cam and headers the car made 371. With the TNT 100 shot, the car made 503 (STOCK HEADS) at 11.5:1 a/f. Now then the difference between then and now are the stage II heads, and the lobe is different on the cam, now a 112. The nitrous profile cam specs are 222-226 566-569 112 AND it will now be a 150 shot w/ 1.75 comp rocker arms, JE forged pistons, rings, and rods. The car on motor made 400 rwhp w/out rocker arms and pistons (which don't add hp I know). So if I gained 130 off of a 100 shot of TNT, and I add a 150 shot to this motor that is set up for nitrous...can I make 600 rwhp?
Old Jul 10, 2003 | 02:20 AM
TNT_Z's Avatar
Default Re: You think this will make 600+rwhp?
And if I can't, and I decide to get a larger lift cam, what cam do I get? Thunderracing has a nitrous cam and a reverse split pattern cam which are 224/227 563/569 114 and 227/224 569/563 114. Ls1 speed also has a good sized cam which is 224/228 581/581 114. What do you guys think?
Old Jul 10, 2003 | 08:55 AM
10secondZ's Avatar
"in theory" you would need a 200 shot to hit 600 rwhp from 400 on the motor..but that's not alway's true..like for instance my car did 376 rwhp on motor but 603 rwhp on the 200 shot...just because it was set up for n20 though i beleive..my cam is 224/232 .568/.573 114 +2 so it would help disperse n20 better out the exhaust...you DO NOT want a reverse split cam on n20 though..bad new's after a while...it can be done..but if you spray say 100 shot an a revers split u would only gain 80 or so..then on to 150 shot u would gain even less ect...plus cylinder pressure would be insanly high..so dont use a reverse split...you could possibly hit 600rwhp with your set up...only 1 way to find out but if i where you I would run the G5X2 cam on spray to make 600rwhp...Later,
Carter
Old Jul 10, 2003 | 11:58 AM
WICKED SS's Avatar
Run a 200 shot! If I had a built bottom end I would be running a 200+ shot all day! I think with your 150 shot you will make around 550-570rwhp. I wouldnt waste time or more money on another cam, if the reason your not running over a 150 shot is fuel then just get a intank pump. There more cheaper then buying a cam. Good luck
Old Jul 10, 2003 | 03:33 PM
Terry Burger's Avatar
Your running around a 160 shot now.
