Oil Coming From Oil Filler Breather
I have a forged h/c ls1 with 1k miles. Just today I had oil on my valve cover and coil packs from my oil filler breather. I also have a catch can. Recently the catch can has had something milky looking in it, but nothing pertaining to a head gasket. I had a piece of the pcv system off of a valve cover and I think moisture got in and caused that. Coolant is still full and green and hardly any loss in oil. Anyone have any suggestions?
Thanks
Thanks
I hooked up a catch can directly off the pvc system with the other side going to the T.body. These cars push alot of oil to the valve train. Having oil in the catch can is normal. With a breather on the valve cover you are sucking moisture into the engine at that point. The engines make moisture every time they start up. Check your tail pipes you'll see. I would keep an eye on your water level. Check the overflow level also. If it goes down you might have a problem.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Sounds like higher than normal crankcase pressure...maybe rings have not seated entirely?
