zo6 cam question
Old Feb 2, 2008 | 04:12 PM
FormulaWs666's Avatar
Default zo6 cam question
I was thinking about putting the zo6 cam and springs in my 98 ws6. Im just looking for a small 30-40 hp gain. Does anyone have any input? The car is my daily driver so im not looking for a huge cam. I have an intake, y pipe, and a magnaflow cat back. Any help would be great thanks a lot guys.
-Dave-
Old Feb 2, 2008 | 04:24 PM
fast01's Avatar
Be ready. You're gonna get a thousnad posts telling you that a swap to that cam isn't worth it, you'll make more power with cam x for about the same cost. Bottom line...it's true. There are a hundred other cams on the market that'll work better for about the same money and drive just like stock. Just do a search and you'll see what I mean.
Old Feb 2, 2008 | 07:39 PM
hammertime's Avatar
On top of that, your small 30-40 hp gain isn't going to happen with the LS6 cam - probably about 1/2 that. If you want those gains, you're probably going to need some good heads along with your mild cam.
Look for something like a Comp 214/220 114+3 XE custom grind. Mild enough that it won't lope noticeably, but should make more power than the LS6 cam.
Old Feb 2, 2008 | 07:54 PM
Evans752's Avatar
I have put this cam in a couple of f-body cars and had very good results considering its a stock 0E cam. They have put down on the dyno 370 to 380 with a little computer tuning but they had just about all the bolt ons(headers, exhaust, ect). I always put the Comp Cam 918 springs and 7.40 pushrods. Car run low 12 and high 11 on Drag Radials and are 6 speeds with gears (3.73, 4.10)and pretty good drivers. Good Luck on your decision.
Old Feb 2, 2008 | 08:26 PM
fast01's Avatar
I agree on this point. My car with an LS6 longblock (2001+ cam and 243's) and bolt-ons put 373hp to the rollers. Those 806 heads aren't even as good as the 853/241's in stock form.
Old Feb 3, 2008 | 12:30 AM
I was thinking that it wouldnt be worth the hours to install it as well. Thanks a lot i will look around some more and see what i can find.
Old Feb 3, 2008 | 08:42 AM
Alt's Avatar
Alt
Well I'm in a similar situation though the cam is laying around and not costing me anything so finding another cam for a price of about $0 is quite difficult. That being said if the 241 heads are milled, how far should they go to achieve close to 11.0-1 compression and what would be the suggested pushrod length to accommodate the milling? Should be a decent increase in power to get me out of the hole till the nitrous kicks in.
Old Feb 3, 2008 | 11:34 AM
hammertime's Avatar
I would mill your heads roughly .020 to get a 64cc combustion chamber, then run a .040 thick head gasket for the best quench. The base circle on the LS6 cam is smaller than the LS1 cam. GM used the same length pushrods with a slightly taller valve to keep everything in check. Since you are removing roughly .034", you should be pretty close with a stock length pushrod. It would be a good idea to measure lifter preload and check the wipe pattern on the rockers to be sure.
Old Feb 3, 2008 | 01:18 PM
Alt's Avatar
Alt
All that being said, even though the 241 heads sitting around are also complete should I look into new springs, hardened pushrods, and/or possibly lighter valvetrain components, or would that be a little unrealistic for the goal of a street cruiser on the bottle?
Old Feb 3, 2008 | 01:27 PM
hammertime's Avatar
You'll probably have to upgrade the springs, and pushrods aren't a bad idea at all. If you want the lighter valvetrain components, just get a set of LS6 heads from Patriot Performance. I keep seeing them on here for ~ $400. They'll have the smaller chambers, better ports, and should have the lighter valves (not sure on the last part, ask Gunnar).
Old Feb 3, 2008 | 01:46 PM
Alt's Avatar
Alt
Granted its always easier to buy something thats on the forum thats been proven time and again, but I have some things lying around. I can clean up the 241's and replace my 853's for the price of head gaskets and fluids so I don't see spending $400 on heads with a history that I am not sure of. If I am leaving power on the bench so be it, I will be 23 in under 2 weeks and would like to get some out of what I have instead of jumping into my "I want to move out of my parents basement and buy a house" fund.
Old Feb 3, 2008 | 04:39 PM
LS699TA's Avatar
Ls6 cam is perfect for a daily driver, the extra 500 rpm and 25-30 hp is well worth it
Who the **** wants to change springs every 20000 miles on a big cam? There's a million reasons not to get a cam if its your daily driver.
