which oil pump?
Old Feb 6, 2008 | 09:28 PM
  #41
taws6m6's Avatar
true true
i thnk i will just buy the new one, couldnt hurt. And i would feel better
Old Feb 6, 2008 | 09:33 PM
  #42
COOKIE MONSTER's Avatar
Originally Posted by taws6m6
so should i port mine or get a tsp ported ls6? Which is my best bet and safest route? My car has logged some miles on it. So would it be good insurance to just get a new one?
You got it! If you have 70K or more, you may want to get the TSP deal or just buy a ported ls6 from anyone. Besides, you're gonna pay atleast half that to port the oil gallies on your current one you have now
Old Feb 6, 2008 | 10:39 PM
  #43
taws6m6's Avatar
Thanks man, sometimes its hard to get a straight answer when asking on this site, 99% of the time i just wind up calling the vendor anyways. But this time i will take your advice and just get a new one, thats what i thought would be the good thing to do anyway
Old Feb 6, 2008 | 11:19 PM
  #44
JScamaro's Avatar
Anyone have an opinion on this slp ls6 heavy duty oil pump with double-roller timing chain?
http://www.ws6project.com/user_stor/...90c1efb46d6ad9
Old Feb 7, 2008 | 06:28 AM
  #45
forcd ind's Avatar
i would be interested if that combo fits under the stock front cover
Old Feb 7, 2008 | 12:28 PM
  #46
zman1969's Avatar
I have a opinion definetly better than stock BUT requires sone grinding on the cover and the pump? correct me if im wrong or you can substitute a LS2 chain - beefier and fits w/o issue.Unless your running some radical cam and lots of spring pressure - run the LS2 another .02c
Old Feb 10, 2008 | 06:35 PM
  #47
BOWTIE's Avatar
Originally Posted by zman1969
this is kinda like arguing over the voltage VS amperage isn't it? so what exactly are you fixing by installing a high volume pump? my point is that in 99% of any of our cars are not going to see any benefit of it so why bother? some say you cant put a price on piece of mind - id don't disagree if your that far into it why not? buy WHY do you NEED the extra song and dance added to your pump? does a stock one make you nervous?
I think you confused me with one of the other posters, I agree that running a HV on stock bottom end is the wrong choice which is why I am going to use a ported/polished, shimmed LS6 pump.
Old Sep 20, 2008 | 08:06 PM
  #48
Vndcatr's Avatar
Anyone running the Katech blueprinted LS6 oil pump ? They say that they're Brand new LS6 G-rotor oil pumps with ported oil inlets. $155 from Byunspeed. This is gonna be for my Vindicator cam . So i dont want to cut corners .. thanks
Old Sep 20, 2008 | 09:17 PM
  #49
eamador11's Avatar
Originally Posted by RareBreed0295
I have no complaints from the TSP Ported Ls6 one...
Same here!
Old Sep 20, 2008 | 11:09 PM
  #50
Summerwolf's Avatar
I bought the SLP oil pump/ timing chain set, sold the timing chain later on but the oil pump looks like really good quality. Have not installed it yet, the cam/heads are going in next month
Old Sep 23, 2008 | 01:27 AM
  #51
BIG BAD BLACKSS's Avatar
Originally Posted by kwiksilverz28
1. That is what people on the internet have said. Is it sufficient? Probably. Is the Melling better? Well, Mine went in perfect, makes great pressure with the high pressure spring, and works great. Shop manager for TR told me they only reason that he stocks ported GM ones is for the internet crowd that has it in their heads that this is the way it is. He said Melling is far superior, and recommend it highly.
I suspect the mark up he has on it is also substantially higher as its an aftermarket part as opposed to a modified part he has to buy from a dealer.
I have the SLP pump and chain, and the chain clears the pump no problem, dont have the cover on yet though.
By Brett Foote | 2026-06-04 05:00:17
