EGR Removal Problems
I removed my EGR this weekend by using the plug in the intake and the plate on the manifold. I put everything back together and now the car is running rough and there is popping coming from the exhaust. Does anybody have any ideas what is causing this. Thanks
I was thinking it might be a bad seal. I took off the block off plate and am going to put it back on and hopefully that was the problem.
Would i need to reset the ecu if i clear the codes with a tuner.
Thanks
Thanks
clearing the computer will set all a/f and spark adjustments that have been made (some may have been made while running poorly) back to factory baseline.
let the computer totally relearn the a/f curve
