How to make my car quit pinging
Is that Jeff's old car? If so, you essentially have my tune, just tweaked a bit, in there. You may need to back off the timing across the board a bit. Mine is pinging too. I know the timing is way high on that tune. If you hook it up to HP tuners you will see it. I was told to highlight all the tables and back them off a couple degrees.
I would get it dyno tuned by a pro. Have them check it out and they will probably back that timing off a bit. Thats what I plan on doing.
