timing chain
Old Feb 5, 2008 | 12:41 PM
WhiteFormula98's Avatar
Default timing chain
Ok, so I am doing a cam install and trying to determine whether or not to buy just a chain or the kit with gears also, I have 100,000 miles on the car
Old Feb 5, 2008 | 01:17 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
We have new Cloyes kits available for $43.99 + Shipping.
Might as well just do that. It comes with an LS2 cam gear, but it doesn't matter in your application.
Old Feb 5, 2008 | 01:19 PM
THEBRAD's Avatar
whats the difference in cam gears?
Old Feb 5, 2008 | 01:27 PM
LS1TECH Sponsor
The LS2 is set up for the cam sensor on the front of the cam rather then on the back. You can use an LS2 in place of the LS1, but not the other way around.
Old Feb 5, 2008 | 01:36 PM
wat kind of chain is it, double roller?
Old Feb 5, 2008 | 01:58 PM
allthrotle's Avatar
I believe the cloyes are single non roller for that price, I know cloyes carries a roller chain but, its still a single. I would do both the chain and gears because they wear together.
Old Feb 5, 2008 | 02:04 PM
DANOZ28's Avatar
the ls2 chain looked much stronger and fit perfect on my car. go for it!
Old Feb 5, 2008 | 02:12 PM
LS1TECH Sponsor
Single Roller, we use them in every single one of our engines with no failures, and we have race cars spinning to 7400RPM.
The LS2 chain is a stronger design than the LS1. There really is no need for an aftermarket setup for what you are doing.
Old Feb 5, 2008 | 02:40 PM
SLP Firehawk's Avatar
i went with an ls2 chain only got it for 30 bucks from gm dealer
Old Feb 5, 2008 | 02:43 PM
THEBRAD's Avatar
i believe they r selling gears and chain for $44 while u got just the chain for $30
Old Feb 5, 2008 | 02:51 PM
LS1TECH Sponsor
Correct, gears and Chain
Old Feb 5, 2008 | 03:33 PM
THEBRAD's Avatar
how much is shipping?
Old Feb 5, 2008 | 04:30 PM
LS1TECH Sponsor
I think shipping to you would be right around $10.00
Old Feb 5, 2008 | 08:58 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Can't go wrong with the LS2 chain
Old Feb 5, 2008 | 09:23 PM
RedRallyeZ's Avatar
+1 on ls2 chain, no need for anything bigger on a basically street car
Old Feb 5, 2008 | 10:35 PM
smokeyrider05's Avatar
: ls2 chain no gears needed.
Old Feb 6, 2008 | 12:06 AM
Camaro396's Avatar
I just did my cam swap. LS2 chain, stock gears.
Old Feb 6, 2008 | 04:51 AM
vettenuts's Avatar
With 100K miles on the car, I would take this offer and install two new gears as well. Its only a few extra bucks (screaming deal) and offers peace of mind. The sprocket teeth do wear and when they do they tend to hold the chain longer (chain wrap) which can break the chain.
Old Feb 6, 2008 | 10:25 AM
JPH's Avatar
JPH
hey vette, hows your project coming along?
Old Feb 6, 2008 | 12:06 PM
vettenuts's Avatar
Just finished establishing the wipe pattern on the new heads on the work bench
