throttle body
Old Feb 28, 2008 | 02:10 PM
Boosted1320's Avatar
Originally Posted by Slvr00Bird
The aim is to increase efficiency and speed of flow.. So if you remove a little material and all of the casting flashes, etc, then the air should flow smoother and give an increase in performance..
It doesnt work that way though. When the pressure is negative on the outside as the air is being SUCKED through it would make no difference. Now if the pressure was positive it would aid in smoothing out turbulence....in say a boosted app. Diagram of how it works. In theory your saying if I put 4" tips on my 2 1/2 exhaust pipe it will flow better....? Same concept just in reverse.
Old Feb 28, 2008 | 03:11 PM
Slvr00Bird's Avatar
If you ran 3in all the way out of the exhaust then it would run better than if you ran 2in...
Not catching your thinking here at all but why would so many people do it and then show gains? Those just imaginary horsepower that are coming in after the p&p and people are b.s.'n it??
Old Feb 28, 2008 | 03:38 PM
Bill Bowling's Avatar
People do report an increase in HP with a ported TB. I have heard of up to 10 HP.
Bill
