Does this sound like a oil pump O-ring problem??
I've done a few installs with no problems.A double row timing chain was installed which you have to force the oil pickup out to line up.Also a 01 oil pump was used (off my car,worked perfect before removed)
So is this a symptom of the O-ring??
Thanks
I found the problem.I forgot to install the O-ring
Mistaked the metal ring on the tube as the O-ring
I installed a new O-ring and pressure was right at 60psi on startup
1. replace the old o-ring with a new one
2. install the oil pick up tube BEFORE the oil pump bolts are installed.
This allows the filler tube to align properly and tightening the bolts after installation of the tube allows it to bend slightly....
The SDPC Rollmaster directions SUK...
your lucky you dont have to buy him a new motor
now I don't feel so bad about my trying to reuse the old O-ring and then having to go back and replace it......
glad to hear you figured out what was wrong before anything got hurt....
