Did a Compression test..think i gotta problem
just for ***** and giggles since my truck went from 382 to 317 on the dyno the other day i did a compression test on all the cylinders..the motor was warm and i unplugged the coil packs and open the throttle and crank it several revolutions like ive always done on my race cars...
the motor is a 6.0 LQ4 with p&p 241 ls1 heads with stock 6.0 head gaskets
#1 175 psi #2 150 psi
#3 164 psi #4 140 psi
#5 180 psi #6 170 psi
#7 155 psi #8 115 psi
BTW it's not just cylinder 8 you should be worrying about, two cylinder side by side should not have more than a 15% difference from each other, I'd do some tests on #4 and #7 as well.
Can you expand on what you were talking about when watching the needle?
By the way, having never done a compression test, all you do is unplug all the coil packs first, then take one plug out at a time, each time thredding your gauge down into the hole, and hitting the key for it to turn over a few times?
Won't it flood by the time your done?
Thanks!
Wish I had enough money to do a shortblock rebuild (and a new clutch and a tranny rebuild, and a 9", and a torque arm and lower control arms, and a lowering kit, and wheels and tires...
CRANKING COMPRESSION TEST PROCEDURE:
1. Make sure engine is at operating temperature.
2. Disable fuel or ignition system. Check what the manufacturer recommends for the proper procedure, it does vary from manufacturer. (I usually pull the fuel pump fuse)
3. Remove spark plugs.
4. Thread the compression tester into the spark plug hole of the cylinder being tested.
5. Block the throttle plate open.
6. Crank the engine at least four compression strokes. Crank the same number of strokes for each cylinder.
7. Record readings.
I'm willing to bet that it's either your valves or rings that are bad as a blown head gasket would give to adjacent cylinders low but equal readings.
7. Record readings.
About how many seconds would that be on an LS1?
Remove the Fuel pump relay and you will be safe to perform the compression test.
Or..............You can do what I accidently did and have the engine start on you while a frined is holding the compression gauge. I thought he was gonna **** him self.
Re'
