best sponser to port my heads.
Old 02-11-2008, 12:42 PM
tasilver's Avatar
Default best sponser to port my heads.
I have a extra set of 241 heads and was going to have them ported. My car is in the shop right now getting a strange 12 bolt installed with 4:11 gears. I would like as little down time as possible. So I was thinking of having these ported. I was going to only do a cam but since I have the heads I figured I would get them ported. So which sponser should I use.
Old 02-11-2008, 12:50 PM
Sharpe's Avatar
Same situation as you are in. Extra 241's. Downtime more important than anything.
But, it was cost prohibative to send the heads anywhere to have them ported. Just didn't make any sense at all. Would have cost damn near the same just to buy Patriots or whatever.
Old 02-11-2008, 04:24 PM
THEBRAD's Avatar
same here i was thinking about having mine ported after i get them back from being milled. but if its that expensive i think im good without it
Old 02-11-2008, 05:48 PM
tilly's Avatar
So it is not worth sending out a bare head to Patriot or Texas-Speed to have them port it ???
Old 02-11-2008, 06:20 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We port customers cylinder heads all the time. Give us a call sometime & we can talk about some of the differences between PRC heads & the competition. I think you'll find tons of good prc results in the dyno section & the 241 heads will use the same port we put into the 5.3l heads!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-11-2008, 06:21 PM
tasilver's Avatar
On TEA's sight it looks like they charge 900 and some $'s for a exchange. Most heads seem to start at $1400 and up. That and the fact that I have an extra set of 241 heads was why I asked the question. Just looking for some opinions on which sponser would do the best job and price, also for anyone that has had these heads ported.
Old 02-11-2008, 06:24 PM
tasilver's Avatar
I will call you tomorrow. Thanks for the response.
Old 02-12-2008, 08:03 AM
WeberRacingEquipment's Avatar
We use Total Engine Airflow and have had great results with the program they run on the 241's. I would give them a call and talk to Mike or Brian.
Old 02-12-2008, 11:43 AM
cdoggy81's Avatar
You can get TSP or PP to do them for $650 or less...
Old 02-12-2008, 02:31 PM
THEBRAD's Avatar
thats not a bad deal
