Light hone fit what rings?
Old Feb 12, 2008 | 03:43 PM
lstvr's Avatar
Default Light hone fit what rings?
If i were to have a light hone on my LS1 block, do i fit standard rings? is there an upgrade available or that you guys would recommend? I am just weighing up which way to go with my oil usage problem. Thanks.
Old Feb 12, 2008 | 04:04 PM
road agent's Avatar
I used Akerly & Childs Xtreme File Fit rings. You can get them from Scoggin-Dickey parts center. Whatever brand you use, make sure they are the right width. There tends to be a difference between the OEM pistons and aftermarket ones. Also make sure your hone finish is compatible with what the rings are designed for.
Old Feb 12, 2008 | 04:31 PM
lstvr's Avatar
I have Probe pistons, do anyone know what rings these use??
Old Feb 12, 2008 | 04:46 PM
JPH's Avatar
JPH
what size are the ring grooves and bore size? 1.5mm/1.5mm 3.0mm and 3.905?
Old Feb 12, 2008 | 05:15 PM
lstvr's Avatar
Stock bore, dont know the rest without stripping it.
Old Feb 12, 2008 | 05:16 PM
JPH's Avatar
JPH
i'm sure the ring sizes are what I said, do you want file fit or drop in and go rings?
Old Feb 12, 2008 | 05:29 PM
lstvr's Avatar
I'll fit the better option as i only want to do it once! That will be file and fit i assume?
