started cam install today!
Old Feb 12, 2008 | 05:03 PM
rjkZ28's Avatar
Default started cam install today!
just like the title says fellas started the cam install today. i have a really quick question, i havent taken the crank pulley off yet, i have an asp underdrive pulley and was wondering what 3 arm puller i have to use to get it off? if someone could chime in and give me and hand i would greatly appreciate it!
Old Feb 12, 2008 | 06:00 PM
mchdg86's Avatar
You can go to autozone and rent a harmonic balancer puller. Here is a link to what you need.
http://www.autozone.com/R,NONAPP986/...ductDetail.htm
Old Feb 12, 2008 | 06:06 PM
rjkZ28's Avatar
thanks for the link, but thats not gonna work, i need the one with 3 arms either to clamp the pulley, or the one that goes on the inside of the pulley and presses on it. thanks though.
Old Feb 12, 2008 | 06:25 PM
mchdg86's Avatar
They also rent the 3 arm pullers but I don't see how one would work on the ASP pulley. Are there 3 threaded holes on the inside of it?
Old Feb 12, 2008 | 06:31 PM
chuckyt1's Avatar
Most after market pulleys have the three holes like a harmonic balancer...
Old Feb 12, 2008 | 06:33 PM
kwiksilverz28's Avatar
No, I think he is pulling the stock one off to replace with the aftermarket one...
Old Feb 12, 2008 | 06:42 PM
Sharpe's Avatar
Lurk!!!
Old Feb 12, 2008 | 06:57 PM
rjkZ28's Avatar
no, i have an asp on there now, i have to take it off in order to install the cam. i was just wondering what other people who had an asp pulley used to get it off.
Old Feb 12, 2008 | 07:04 PM
socmguy's Avatar
Restricted User
You have to get three bolts that will fit in there and use the flat removal too to get it off. Not the three jaw.
Old Feb 12, 2008 | 07:11 PM
Gun5's Avatar
crows foot
Old Feb 12, 2008 | 07:22 PM
OH. Get the right bolts and use the steering wheel puller. Don't risk bending it with the 3 claw...
Old Feb 12, 2008 | 08:34 PM
THE CHOP SHOP's Avatar
I did mine with the Chrysler Harmonic balancer tool from AZ. I think those bolts are metric and finding metric bolts that will work has always been tough for me. There are alot of people that have done it with the Chrysler tool but use your discression as to whether it will bend a solid chunk of steel like that. The only down side was I got a few really small marks from pulling it of. It was really easy though.
Old Feb 13, 2008 | 01:41 AM
rjkZ28's Avatar
so this will work then http://www.autozone.com/R,NONAPP986/...ductDetail.htm
Old Feb 13, 2008 | 08:33 AM
The link does not show anything but it is the one labeled OEM# 27139. The only thing I realized is I have a powerbond so I am not sure if there are any differences. There actually was a post with step by step instructions I pulled up in a search when I pulled mine off a while back. But I searched under powerbond removal.
Old Feb 13, 2008 | 10:20 AM
Krab's Avatar
Yes, the best thing to use is the crows foot (harmonic balancer puller). You do have to hunt the right bolts down (M8 1.25, I believe). Good luck with the install. Remember to hold up the lifters during the spring swap.
Old Feb 13, 2008 | 10:50 AM
rjkZ28's Avatar
alright, does anyone know the right size bolts everyone keeps mentioning and would like ace hardware carry them?
Old Feb 13, 2008 | 11:28 AM
eallanboggs's Avatar
I use Posi-Lock. Best puller made bar none. You can get it at Sears. It's expensive so you're better off renting one from AZ if you only plan to use it once.
Old Feb 13, 2008 | 11:51 AM
rjkZ28's Avatar
this is what i just went out and bought from sears,it came with 3 diff size bolts i test 2 of them out and it looks like it may work.
http://www.sears.com/shc/s/p_10153_1...monic+balancer
