head help
Old Feb 13, 2008 | 11:03 AM
slolt1's Avatar
Default head help
hey, i am on a real tight budget and was told that my heads are junk but i wanna know what will be the best head.
i have a set of 98 model heads that has double valve springs and has been ported by patriot, i was told it was some of the first ones that patriot did.
the car ran well with the set up with a small cam,i am changing some stuff up and going with a large cam.and was thinking of a 5.3 head but i want some help to decide what i need thanks
i am building the engine stock but with forged internals and will be spraying about 150-175 cam is going to be a ms4 thanks for any help
Old Feb 13, 2008 | 11:20 AM
99blancoSS's Avatar
Look for some used heads to save a ton of money. Doing it that way you can afford a nicer head. Nothing wrong with used heads if you dont pay to much for them.
Old Feb 13, 2008 | 12:48 PM
slolt1's Avatar
what would be a good used head to look for
Old Feb 13, 2008 | 12:56 PM
teke184's Avatar
why not have your heads checked out? for a fraction of the cost you may find they are pretty decent.
if nothing else the results will help you sell them to recoup some $$
what would make them "bad" for a bigger cam if they worked well for the smaller one?
either way you'd have to check ptv clearance.
Old Feb 13, 2008 | 01:26 PM
slolt1's Avatar
i am going to repl the pistons,i had just talked to some people that said that the 98 heads are junk,i am unsure of who did the port work, i was told it was patriot and was told that bo white did the port work.
i purchased the complete engine with the heads but the set up that was in the car that i bought it from ran 7.40 motor and 6.60 on spray.
i am unsure of how much spray i have heard deferent from everybody
the times is 1/8 mile
Old Feb 13, 2008 | 10:00 PM
Bo White's Avatar
I can tell ya if I did em or not, I have only done a few sets of 97-98 heads for customers.
Old Feb 14, 2008 | 05:57 PM
slolt1's Avatar
how could you let me know would i need to send you some pics? or is there a certain # ?
it was suposed to have 1 of your throtle body on it also
and thanks for chiming in
Old Feb 14, 2008 | 06:45 PM
98RedZone's Avatar
Why were you told they were "junk"? If its just because they are 98's then don't listen to them.
Old Feb 14, 2008 | 07:32 PM
slolt1's Avatar
you are corect thats what i was told.i kinda thout they were just wanting to make a sell,sometime tomarow i will post some good pics and let everyone take a look at them
Old Feb 16, 2008 | 09:54 AM
Bo White's Avatar
PM me who you got them from and your location, if you dont mind.
Old Feb 21, 2008 | 11:47 AM
crainholio's Avatar
The only glitch I've seen with early Patriot heads was a bad batch of valvesprings, which Patriot consistently replaced whether they failed or not. No complaints on their porting or chamber work, just the springs and they're easily swapped.
