please help!!! LSX noob needs cam help
Old Feb 13, 2008 | 11:36 PM
98 4X4 burban's Avatar
Default please help!!! LSX noob needs cam help
i am doing a 6.0 lq9 swap into a 98 suburban and i want to change the cam but not the converter. what would be the best/biggest cam for the stock 6.0 without having ptv issues and not needing a bigger converter?
looking for more torque is the big thing with hp gains second and a nice semi rough idle third.
Old Feb 14, 2008 | 06:20 PM
mchdg86's Avatar
A 224 cam will fit your needs quite well. If you want a semi rough idle go with the 112 LSA and try to get the idle as low as you can with out drivability issues.
Old Feb 14, 2008 | 10:13 PM
hammertime's Avatar
I wouldn't worry about the HP at all in a heavy suburban, especially since you are retaining the stock converter. Also, a semi rough idle that will be happy with a stock converter is somewhat of a pipe dream. Anything with more than a noticeable lope is going to have a tough time idling in gear without some help.
I'd suggest a custom cam to best meet your needs. A Comp 210/218 .595/.590 110+0 on XFI lobes would make excellent power across the board, with an emphasis down low.
