Valve Spring/Rocker Arm question
Thanks,
Bobby
Either get your stock ones rebuilt by Harland Sharp or go with a standard 1.7 aftermarket not that variable lift tech.
Look around for a Cam Dr sheet, I know Patrick G has some with the regular FM14
On these the rate is about 50 intake and 51 exhaust (XE=53 and XE-R= 49)
so the high lift must be more than that at some lifts.
I had one but the site hosting died and it is lost.
Thanks,
Bobby
150# at 1.800"
440# at 1.100"
Coil Bind at: 1.030"
Max Lift: .700"
Spring Rate: 402#/in
Spring Weight: 95 grams
OD 1.300"
