383 power
383 stroker Prc 2.5 LS6 heads 2.04 1.57 with 248/254 .611 .613 114 wiend LS6 style aluminum intake or same combo with tfs 215 heads
Oh yeah A4
I am hoping for 470rwhp and about 450rwtq with a 4.125 should be a torque monster
Livernois Stg III's with 231/238 112LSA Cam Motion cam
http://rides.webshots.com/photo/2593...rK?vhost=rides
when dynoed car had...
- ZR1's wih MT ET Radials at 20 psi (forgot to add air)
- 3" Steel driveshaft
- Moser 12 bolt w/ 3.90 gears
Only pass was 11.47 @ 124.3mph (broke d/s before and trans after)
Otherwise you would make a 383 by using a stock LS1 block honed to 3.905" and installing a 4" crank with the appropriate rod and piston set.
IBADAIR beat me to it....
I won't use aftermarket sleeved blocks.
We used an Iron 6L block bored to 4.060".
Eagle crankshaft (stock stroke) that we had offset ground to a 3.70" stroke.
SBC 6.125" rods.
Custom Pistons.
