noisy valvetrain .......
Old Feb 15, 2008 | 08:49 PM
riceless90's Avatar
Default noisy valvetrain, help needed...........
i have a 2001 ls1 with only 57k on the clock that has a noisy valvetrain and it is driving me nuts.
i have installed an ls6 ported oil pump,new comp lifters, new hardened stock length pushrods,new stock cam,new arp head studs stock gaskets, new arp rod bolts(so i have checked rod bearings also),i have tried different oils and filters . but nothing fixes the problem. i have not driven the car much or hard since the install. the engine has had this noise since i put it in the car.
it is in a 1991 rx-7 btw. the 2001 camaro donor car had a few bolt on mods but it did not look like the engine had been touched.
here is a video i took today of the car:
http://youtube.com/watch?v=tT4dm3sVniM
any help would be greatly appreciated.
thank you
-robert
Old Feb 16, 2008 | 08:24 AM
riceless90's Avatar
anyone got any ideas?
Old Feb 16, 2008 | 09:51 AM
PREDATOR-Z's Avatar
Check the O-ring on the oil pump. If pinched it will do that.
Old Feb 16, 2008 | 10:01 AM
todds87ss's Avatar
Default sewing machine noise
that noise is considered by many to be "normal" for the LS1 of that year. I have quieted mine down some using quality valve springs.
Good luck,
Todd
Old Feb 16, 2008 | 02:06 PM
Assman's Avatar
My car sounds about the same and it drives me nuts, I never replaced the lifters when I did my h/c swap though and wish I would've now...
Old Feb 16, 2008 | 04:35 PM
SladeX's Avatar
I was having the same issue on mine. Oddly enough, if I added a half a quart of Bardahl's Oil stop Leak it'll keep it quiet on my car. I suspected a lifter that wasn't keeping up vs the double springs I was using.
Mine would get pretty annoying on a long drive. After 1 hour, it'd tap really loud, only a good rev to bring up pressure and then let idle to settle it would "pump" itself back up and be gone.
Check the oil pump o-ring and get a new one and see if that solves it.
Old Feb 17, 2008 | 09:11 PM
riceless90's Avatar
i installed a new o-ring with the ls6 oil pump and double checked it to make sure it wasnt pinched.
thanks for the input.
anyone else?
Old Feb 18, 2008 | 06:17 AM
PREDATOR-Z's Avatar
Check it again.
Old Feb 18, 2008 | 09:45 AM
Assman's Avatar
If the o-ring was pinched, would the oil pressure be low too?
Old Feb 18, 2008 | 10:13 AM
riceless90's Avatar
if you look in the video my oil pressure is fine.
Old Feb 18, 2008 | 10:25 AM
SladeX's Avatar
Check preload of the pushrods, did you use a pushrod length checker on it?
Another theory I've been passing around on mine is that the double springs I'm using may be strong enough to force a lifter to collapse a bit and not under load not allow it to get up. I've noticed that if I let it idle (or coast for a good min or 2) the tick will go away.
Though my more semi-permanent solution of adding half a quart of stop leak seems to be working great now for over a month.
Old Feb 18, 2008 | 05:31 PM
Assman's Avatar
I was saying theoretically wouldn't the pressure be low if the ring was pinched. I'm trying to figure mine out at the same time as you.
Old Feb 18, 2008 | 08:36 PM
SlickWillie's Avatar
Just got a longblock put in my car and it acted fine for a few weeks of driving it on the weekend and now it is making the same noise. I pulled off the valve covers and everything looks to be ok. Sounds like it is coming from the lifters but i have no idea.
