oh snap, carnage pics inside!!
Old Feb 16, 2008 | 07:01 PM
MadMike's Avatar
Default oh snap, carnage pics inside!!
so a few buddies and i decided today we would pull the engine in the camaro.
pulled it out the top and found this inside
BALLSSSSSS. anyone know a good company for fixing heads ? i really cant afford new ones.
this is gonna get pricy really quick, as i see it i need the head repaired, new pistons and the neccessary rebuild parts (bearings gaskets etc.) the cylinder wall looks ok, btw this is cyl #7. woe is me
Old Feb 16, 2008 | 07:04 PM
odarabla's Avatar
Was it making noise or smoking?
Old Feb 16, 2008 | 07:06 PM
MadMike's Avatar
its been smoking for a while now, and yes , i launched from a light and a horrible noise followed kinda like a broken lifter noise but deeper and louder
Old Feb 16, 2008 | 07:11 PM
Ryan'sSS's Avatar
I would stay away from those pistons in the future.
Old Feb 16, 2008 | 07:13 PM
MadMike's Avatar
any recommendations on pistons ? i intend to spray eventually.
Old Feb 16, 2008 | 07:34 PM
odarabla's Avatar
Agreed!! You could try the Diamond pistons. I hear they are really good.
Old Feb 16, 2008 | 07:46 PM
Ryan'sSS's Avatar
Weisco, JE, Diamond then Mahle.
That being said, I just had my motor rebuilt with Mahle pistons. And both my mechanic and machine shop have nothing but good things to say about them.
Old Feb 16, 2008 | 08:28 PM
MadMike's Avatar
cool, ill check them out thanks !
Old Feb 16, 2008 | 09:26 PM
MadMike's Avatar
talk to me about pistons, whats with the dish style and flat top, explain im kind of a newb at internals. what should i be looking for, i intend to spray quite a bit later, but the car is also driven every nice day i can. what do i need to know about pistons and what the differences are?
Old Feb 16, 2008 | 10:12 PM
Ryan'sSS's Avatar
Looks like you were running flattops.
Old Feb 16, 2008 | 10:50 PM
massls1guy's Avatar
Question to internal experts - what caused the top of the piston to break off? Was it a problem with fly cutting? Meaning too deep, came too close to the ring land?
Old Feb 16, 2008 | 10:56 PM
Ryan'sSS's Avatar
They are after market pistons so they should be valve reliefs cut from the manufacturer.
Could be a number of things that caused that.
Old Feb 16, 2008 | 11:17 PM
84z28Camaro's Avatar
Mahle pistons are forged/coated. Come dished(i think) or flattop. Look on one of the sponsors sites like SD's should give you specs on em there.
Old Feb 16, 2008 | 11:57 PM
CO99Z28Vert's Avatar
Damn that sucks. I know this sounds retarded but I hope something happens to my engine so I can forge it. I will never spend the money otherwise and since the engine will be out I will be more motivated and the Fiancee would understand more then lol.
The wedding will be put off baby until I forge my engine since its a priority with all my money...think that will work?
Good luck getting it back together.
Old Feb 17, 2008 | 05:19 AM
LS1MCSS's Avatar
If it don't work for this Fiancee, don't try it on the next one.
Old Feb 17, 2008 | 06:04 AM
waldershrek's Avatar
Oh snap is right! God damn......
Old Feb 17, 2008 | 09:20 AM
nbm00ss's Avatar
Go with Mahle. Thunder racing sells them. you are running flat tops with valve reliefs. They will probably have 2 choices for the depth of the fly cutting, for safety sake i would get the deepest ones and be sure you have piston to valve clearance so you stay away from as many problems as possible. They have an some dual coating process and my engine builder also recommended them for my 347 build which is almost done.
Old Feb 18, 2008 | 02:16 PM
CamaroSS621's Avatar
I cant believe that. those freakin pistons were over $1,000!! they were flat top Diamond pistons with valve reliefs.
Old Feb 21, 2008 | 11:33 AM
crainholio's Avatar
Two common causes for a failed ringland on a good piston (and Diamond makes very good pistons) are:
1.) Ring end-gap set too tight, ends butt together at operating temp.
2.) Excessively lean fuel:air mix. Looking at the adjacent head chamber, that one appears to be slightly rich...whereas your failed chamber and piston crown show slightly lean burn conditions. Partially obstructed injector maybe?
Old Feb 21, 2008 | 11:47 AM
chromeplated500's Avatar
that sucks... side not though... does the tape on the fneders work pretty good... ive never seen that I'm gonna have to test that out sometime soon...
