Headers for lowered ss
They are very affordable but the Y pipe does bang on the drivers side which I took care of with a little rigging. If you do install headers go ahead and install poly motor mounts so with whatever headers you get you dont have to worry about the banging y pipe.
I wish I would have done the motor mounts since they were so easy to get too when the headers were off.
Also the Y pipe was a little too small for the factory I pipe but from what I read that happens too pretty much any aftermarket Y set up, I just took it down to a muffler shop and for $25 had them weld the Y to the I pipe.
Of course I probably would have went long tube but for the $250 I paid for the headers off Craigslist I couldnt complain.
Good luck on whatever you decide to get and im sure other people will chime in with lowered cars with different set ups.
no ground clearance issues so far.
its a cutout thread but it shows you the ground clearance.
also Pacesetters fit "PERFECT" no problems.
https://ls1tech.com/forums/showthrea...ght=cutout+dmh
