cam, spring question
Old Feb 17, 2008 | 09:31 PM
167camaro's Avatar
Default cam, spring question
I just got a really good deal on a few brand new cam swap parts and need to know if the springs i got will work with the cam i have. Here is a list of the parts i just got, COMP Cams 54-414-11 specs: 1300-6300 Duration Advertised IN 269 EX 273 @.050" IN 216 EX 220 Lift IN .525 EX .532 Lobe Sep. 114 Degrees
The springs are comp cams beehive part #26915-1
The rocker arm kit is a comp cams 1.85 ratio.
Now with my limited math skills, with the 1.85 ratio rockers and this cam my gross valve lift will be .571 on the intake and .578 on the exhaust. Will the springs i have here handle that much lift? Does this sound like a good combo for a street driven car? Possibly a little nitrous in the future. Thanks in advance for any input. Rest of mods i currently have are in my sig. Aaron
Old Feb 17, 2008 | 10:36 PM
167camaro's Avatar
If it helps the spring rate for these springs is 313 lbs/in
Old Feb 18, 2008 | 10:40 AM
JPH's Avatar
JPH
I would use comps #918-16 springs with the 1.85s or a Crane #99831-16 spring set.
Old Feb 18, 2008 | 11:24 AM
167camaro's Avatar
Ok so the springs i have now won't work at all or the 918s would be better?
Old Feb 18, 2008 | 12:40 PM
JPH's Avatar
JPH
No, the #915's will work, but the added pressures of the 918's, they would be better for the 1.85 rockers IMO.
