395 Stroker!
Old Feb 18, 2008 | 03:47 PM
FEF84's Avatar
Default 395 Stroker!
Has anyone done a 395 stroker? Looking for numbers and what all was required to do it crank, port or etc... let me know thanks
Old Feb 18, 2008 | 04:40 PM
ROCNDAV's Avatar
You have to clearance the block at the bottom where the rods will come in contact with it. 395 stroker kits will consist of new crank and rods as well as pistons. You will need better flowing heads.
Old Feb 18, 2008 | 06:06 PM
99ssleeper's Avatar
I'm no help here, but I'm also interested to see what other would have to say about a 395/396 LS1. There doesn't seem to be many around.
Is it safe to clearance the block for the 4.125 crank and rods? Does the oil pan need to be clearanced? Any other issues?
Old Feb 18, 2008 | 06:15 PM
ROCNDAV's Avatar
There are several guys on here that have. A lot of people are not for the 4.125 stroke because the stroke is longer than the bore diameter, most tend to favor the larger bore, shorter stroke. Some people also say the longer stroke runs into the thinner part of the sleeve and yet others say that due to the location of the oil ring there are also issues.
It doesn't take much to clearance the block. I did mine with a simple air die grinder. Nothing needs to be done to the oil pan, but the windage tray does have to be shimmed with washers.
Old Feb 18, 2008 | 10:29 PM
Mike94ZLT1's Avatar
A 5.4 liter Ford has a 3.552" bore x a 4.165 stroke, I just learned that the other day! That's a crazy ratio right there.
Old Feb 18, 2008 | 10:38 PM
rickyracer25's Avatar
man before I found out that I cracked my block I really wanted to do this. Couldn't really get any info on this combo. Good luck and let us know how the numbers turn out!!!
Old Feb 18, 2008 | 10:43 PM
BerryWS6's Avatar
I just finished my 396 build yesterday, clearenceing the block is easy, had to grind on the oil pan too where #2 rod bolt touched
I also used 6.250 rods so the rod to piston angle is not as harsh and helps cut down on piston to cylinder wall pressure. but that does make for a shorter compression height
Old Feb 19, 2008 | 12:15 PM
FEF84's Avatar
so how much would it cost for a local shop do put this bad boy in? Also what kind of performance numbers are we guessing here just looking for some ball park numbers. Also head and cam suggestions for this combo would be much appreciated. Thanks
Old Feb 20, 2008 | 12:46 AM
FEF84's Avatar
anyone?
Old Feb 20, 2008 | 02:45 PM
darrellk's Avatar
I have a lunati 395 stroker kit for sale. Piston rods and crank all in exellent shape pm me if interested
