cam only 10 sec combo..???
Old Feb 21, 2008 | 07:22 PM
dameter21's Avatar
Question cam only 10 sec combo..???
Just wanted to see other guy's combo's they used to achieve the 10 sec barrier. specifically looking for cam only nitrous cars.
Old Feb 21, 2008 | 07:51 PM
radz282003's Avatar
I know a dude here that runs a cam only MS3, LTs, short duals, 4.10s (I think,) weight reduction, slicks, skinnies, FAST 90/90, and something like a 4400 stall, that's scratched 10s and is on the borderline of 9s on the spray.
Old Feb 21, 2008 | 08:14 PM
oneblackTA2000's Avatar
Obviously going in the tens with a "cam only" you would have to look at other things such as your driveline and your suspension. You would want a rear end that could take the hard launch and a clutch that could take the abuse. You would then want the proper suspension setup for the 1/4
Old Feb 21, 2008 | 08:16 PM
jessedale98's Avatar
well thats almost accurate.
If you want a 10 second cam only car, you had better put the bitch on the atkins diet. Thats probly the most important thing.
Old Feb 21, 2008 | 08:27 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
My 02 Z28 went 6.8xs which would have been a sub 10 sec pass. It had a F13, 3K stall, 3.42s and a TNT 150 shot
Old Feb 22, 2008 | 07:35 AM
smokeum99ta's Avatar
I went 10.s with a g5x2 cam, headers, true duels with dumps, ls6 intake, 80mm bbk tb, 150 shot of nitrous, 4.11's, qa1's on all corners, sfc's, lca's and some other typical bolt ons. Really wasn't that hard to do with a cam only.
Old Feb 22, 2008 | 10:44 AM
socmguy's Avatar
Restricted User
A friend of mine is running mid 10s with a 224 cam, typhoon intake, 150 shot, TH400, M12bolt, full suspension and **** TON of weight reduction.
Old Feb 22, 2008 | 10:59 AM
andrew69_04's Avatar
good tires are a big plus!
Old Feb 22, 2008 | 12:09 PM
blu1's Avatar
Love the comments, "it wasn't that hard with the addition of a 150 shot" haha. Well no kidding lol.
Old Feb 22, 2008 | 12:15 PM
dhpewterz's Avatar
I went some 6.90's cam only but didnt get a 1/4 time cause they said the timers were messed up im pretty sure that would have been a 10 sec pass. I have a trex, th350, moser 12, weight reduction, fast 90/90, all boltons except ewp,28x10.50 slicks, all umi suspension.
Old Feb 22, 2008 | 12:46 PM
sciff5's Avatar
Demonicbird00 went 10.99 at around 127mph with a custom ground cam on stock heads, with a fast 90/90. That was with a 6mt.
The guy can bang gears. I think this is the cam I am going with, because it fits on stock heads without flycutting.
Old Feb 22, 2008 | 01:14 PM
rickyracer25's Avatar
Joe here in amarillo had G5x3, ewp, prc 5.3l 2.5, full bolt on and went 10.9 with a 6000 da if i remember correctly... I know cause he beat the **** outta me
