Special fitting for rear oil galley?
Old Feb 22, 2008 | 02:29 AM
ronald so's Avatar
Default Special fitting for rear oil galley?
I purchased a fitting locally so I could plumb in my accusump. I wanted to have it feed directly into the oil galley and the only available location was at the drivers rear. (front is not accessible due to alternator)
The issue i'm having is that the fittings head is way to large to seat down against the block. Its 1" hex head and has a crush washer on the back side of it.
its a 16x1.5 to -10 fitting.
Do you know if the earls fitting will work.
Was wondering if their hex size is smaller. http://store.summitracing.com/partde...EAR-9919FFJERL
If anyone has any other recommendations, i'd appreciate it. I'd prefer to go directly into that oil galley.
Thanks Ronald
Old Feb 22, 2008 | 10:43 AM
405HP_Z06's Avatar
I think this is what your looking for:
Tapping into the rear is the desired spot because it is on the clean side of the filter. These are available from Wheel to Wheel.
Old Mar 13, 2010 | 02:39 PM
rsx664's Avatar
up from the dead, but where can I get this adapter???
At least I did search first
Old Mar 14, 2010 | 02:59 PM
rsx664's Avatar
any help????
Old Mar 14, 2010 | 03:23 PM
matty b's Avatar
its fairly obvious from the post that they can be bought at Wheel to Wheel. On my screen the answer is about an inch above your post.........
Old Mar 14, 2010 | 03:47 PM
rsx664's Avatar
yes, but wheel to wheel no longer exists, unless it is called something other than wheel to wheel.......
Old Mar 15, 2010 | 02:36 PM
OutToWinPAHC's Avatar
I am also looking for this for the same reason, anyone find them?
Old Mar 16, 2010 | 06:06 PM
rsx664's Avatar
anyone??
Old Mar 22, 2010 | 06:45 PM
another bump, anyone?
Old Mar 24, 2010 | 05:00 PM
http://www.pirate4x4.com/forum/showthread.php?t=816350
Old Mar 24, 2010 | 05:22 PM
jkkaz's Avatar
That inlet looks different then what I'm used to seeing. Lingenfelter makes one that looks different then that. It had an inlet and outlet. There's also another way to do this with a screw in adapter over the oil filter screw where you can either run the oil filter in the stock location (which really exposes the filter) or relocating the filter, cooler and accusump with a screw on base. I think it was Canton that made those oil filter adapter types.
Old Mar 29, 2010 | 01:44 PM
sparkwirez06's Avatar
http://97.74.103.94/files/metric.pdf about half way down there is a 16mmx10 banjo fitting, just wondering how the oil flow would be through this fitting?
Old Apr 2, 2010 | 04:22 AM
Avaid Oil Systems 818-998-8991 They will have the part!!
Old Apr 2, 2010 | 06:20 AM
427's Avatar
427
I have the fitting in the picture in stock.
Kurt
Old Nov 24, 2016 | 01:01 AM
Tomis's Avatar
Does anybody knows where to get one?
Old Nov 24, 2016 | 08:19 AM
KCS's Avatar
KCS
Moderator
Did you miss the last two posts above yours?
Old Nov 24, 2016 | 10:28 AM
Tomis's Avatar
I was wondering if somebody could share the link to purchase it somewhere online. I checked AVAID website, but could not find it there listed separately.
Old Nov 24, 2016 | 10:53 AM
KCS's Avatar
KCS
Moderator
427 is Kurt Urban, who has them in stock under PN KUP1008. He isn't a sponsor so its against the rules to post a link with pricing, but you should be able to easily find it if you found this 8 year old thread.
