Help Please!! car wont start after cam install!!
Old Feb 23, 2008 | 11:57 AM
DunnoWhoThisIs's Avatar
Default Help Please!! car wont start after cam install!!
i was wanting to know if there is any way you can install a cam 180 out in a ls1.. i lined up the dots and everything, but when i turn it over it wont hit a lick... turns over fine, getting fuel through the fuel line, and its getting fire, but after the install, when you turn the key on the turn signals light up on the dash and so does the bright light signal... did i miss a connection here?? did i plug something back wrong??? please help me!!
Old Feb 23, 2008 | 12:01 PM
chewy99ws6's Avatar
If you lined it up dot to dot you are fine, do you have theft lock on your car? if so try and disco your battery and reconnect it, double check all your connections. See if any of that helps.
Old Feb 23, 2008 | 12:43 PM
Camaro396's Avatar
Double check all your connections, coil pack plugs, and whatnot.
Old Feb 23, 2008 | 12:46 PM
05JUDGE's Avatar
It sounds like something isn't plugged in all the way maybe...Make sure your MAF is plugged in and any other components you unplugged like your fans or anything else.
Old Feb 23, 2008 | 01:15 PM
DaveX's Avatar
If the dots are lined up it should be ok, although there was a rash of cams that were ground 180 off going around for a while. It sounds like an electrical problem to me. There aren't all that many connections to disconnect for just a cam install though. And it would still start without the maf and fans plugged in, as well as some others. Hopefully you disconnected the battery for the install.
Old Feb 23, 2008 | 01:46 PM
yeah i disconnected the battery during the install.. i put new lifters and pushrods and valve springs in.. i talked to shane from tr and he said that it may have too much lifter pre-load hanging the valves open because i have 1.75 rockers.. so im switching back out the rockers to see.. what would make my turn signals and bright light indicators to be illuminated??
Old Feb 23, 2008 | 03:29 PM
DaveX's Avatar
Don't know about the indicator lights but that's what makes it sound like an electrical issue of some sort. Did you disconnect the ground cables on the back of the heads for any reason?
Old Feb 23, 2008 | 03:30 PM
THE CHOP SHOP's Avatar
Did you check to make sure you did not bump the hazards and hit the highs on? Just checking.
Old Feb 23, 2008 | 08:33 PM
vettenuts's Avatar
New lifters and pushrods, did you measure for length?
Old Feb 24, 2008 | 04:42 PM
aright.. figured out the problem.. turns out one of the ground wires that goes to the back of the head came out of the end.. so i didnt have a ground hooked up.. i just spliced it and ran it up further on the motor.. started right up... dash lights work good.. but now my heater wont switch from defrost and feet to anything else for some reason... any ideas???
Old Feb 24, 2008 | 05:05 PM
98Camarod's Avatar
Glad to see you got most of your problem fixed. The last part of your problem is that there is a tiny line that goes to the rear of the manifold has to be plugged in. Then you will have all of your problems fixed for now.
Old Feb 24, 2008 | 05:09 PM
well thanks... ill have to check that out and see if its unplugged.. i hope so.. cuz heat in only those areas kinda sucks!!!
Old Feb 24, 2008 | 05:21 PM
yep thats what it was!! went out there and hooked it back up and it started working!!! thanks for your help guys!!!
Old Feb 24, 2008 | 05:34 PM
98Camarod's Avatar
No problem, that is what this site is for.
Old Feb 25, 2008 | 08:14 PM
The infamous ground strap. Glad to hear it was that simple.
