PRC Heads
Old Feb 23, 2008 | 01:31 PM
55LS1's Avatar
Default PRC Heads
Finally ready to buy heads, trying to decide between these two heads:
PRC Stage 1 LS6 Heads with double springs or PRC 2.5 5.3 Heads. What should I go with & why. Here's what I'm working with:
Stock bottom end
MS3 on 113
Fast 90/90
1 3/4" Headers/ 3" Exhaust
3800 Stall
4.11 Gears
Old Feb 24, 2008 | 11:52 PM
55LS1's Avatar
Anyone? Looking to place an order within a few days, hoping to get some pointers from people who have actually ran these.
Old Feb 25, 2008 | 12:38 AM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
You are probably not getting the responses because this is where the external talk goes on. I rarely see these people in the Internal section.
Depends on what your wanting to achieve dynamic/static compression-wise. Stages are refering to your valve size. I would probably stick with a stock sized valve, but others will tell you that it is a restriction I am sure of it. Honestly if I had to pick between the 2 it would be the LS6 hands down. They will both lay down the power, just depends on what you plan on having the car do really.
Moving to Internal for further feedback.
Old Feb 25, 2008 | 11:41 PM
Midnight02's Avatar
Bump for this one as I'm trying to make the same decision....
Old Jun 9, 2008 | 08:48 AM
LS1C5Vette's Avatar
Bump again!
Old Jun 9, 2008 | 09:14 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You can't go wrong with the 5.3L heads. They give a bump in compression, which will definitely make that camshaft drive and perform as intended! Also, they have a slightly smaller intake runner, so you don't have to turn big RPM to make good power.
Give me a call or shoot me a PM if I can help with anything on your combo!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 9, 2008 | 09:29 AM
venom ws7's Avatar
I agree with Mat PRC 2.5 5.3 heads will work awesome MS3 cam.
Old Jun 9, 2008 | 10:43 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Another vote on the 5.3s
I run them myself
