Idle surge help
Old Feb 23, 2008 | 02:31 PM
LS1axle's Avatar
Default Idle surge help
My idle sures when the car is running and not in gear. The gauges dont move it just sounds like the car is reving up alittle and then it stops. Im all stock and just replaced the plugs and wires. I only have 30k on my car.
Old Feb 24, 2008 | 01:25 PM
LS1axle's Avatar
anyone?
Old Feb 24, 2008 | 01:53 PM
shoemike's Avatar
does it pull while in gear as well?
it sounds like you might have a vacuum leak.
Old Feb 24, 2008 | 06:18 PM
LS1axle's Avatar
I really dont notice it when Im driving. I only notice it if im at a stop light or drive thru. It only revs up a bit and then goes back to normal.
Old Feb 24, 2008 | 06:30 PM
Shawn @ VA Speed's Avatar
x2 on the vacuum leak
Old Feb 24, 2008 | 06:34 PM
odarabla's Avatar
ollyshawn's Avatar
you might try cleaning your maf sensor
Old Feb 24, 2008 | 09:26 PM
LS1axle's Avatar
I will give that try.
Thanks
Old Feb 26, 2008 | 12:22 AM
LS1axle's Avatar
I cleaned the MAF today and the car ran fine I drove ten miles turned it off and then drove another three miles and turned it off. I went to start it again and the air bag light and the service engine light both came on and will not shut off. What do you guys/gals think it could be?
thanks
Stephen
Old Feb 26, 2008 | 12:25 AM
99z28monster's Avatar
what did you clean the maf with? Make sure all your Vac lines are pluged in and the hoses are not pinched or torn.
Old Feb 26, 2008 | 01:22 AM
LS1axle's Avatar
There is a vac line behind my passenger head light that is unhooked? Is there a diagram of the all the vac lins?
thanks
Old Feb 26, 2008 | 01:09 PM
LS1axle's Avatar
Anyone want to help the newb?
Old Feb 26, 2008 | 05:39 PM
LS1axle's Avatar
Anyone?
Old Feb 26, 2008 | 05:58 PM
badass99ss's Avatar
Use a thethoscope or grab a piece of 5/8 fuel line and stick it to your ear. Move around your engine bay and listen for a hisssss. Check all vac lines.
Old Feb 26, 2008 | 06:56 PM
LS1axle's Avatar
Is there a vac line diagram anywhere? I found a black plastic line unhooked behind the passenger head light but I cant find where it needs to be hooked up?
Old Feb 26, 2008 | 06:58 PM
DaddySS's Avatar
The small hose on the passenger side connects to the plastic adapter at the back of the intake and is the HVAC source vacuum line. You probably knocked it of doint wires? You will need a mirror and thin arms to reach back and plug it back in.
Old Feb 26, 2008 | 07:58 PM
chpmnsws6's Avatar
The hose down by the passenger side is your vacuum reservoir tank.
Old Feb 26, 2008 | 08:19 PM
LS1axle's Avatar
I traced it back and it looks like it goes back toward the intake but i dont know where it connects under the head lamp? My air bag light blinks and then the stupid service engine light comes on.
Old Feb 26, 2008 | 10:12 PM
transAm-98's Avatar
There is only one spot on the back of the intake where you can plug it in. It's a little hard to get with everything bolted up but it can be done just feel around a bit. should be right under the MAP sensor.
Old Feb 26, 2008 | 11:17 PM
LS1axle's Avatar
The intake side is hooked up. Where does the other end go?
