does everyone install this cam straight up? Just wondering if anyone has done any different and what were your results?
Mine went in straight up
Mines straight up to (dot to dot). Mine had +2 degrees advance ground into it.
cool, thats what i will do then, just checking. Hey, has anyone used tims tool for dual springs? Does it work good?
Yes, the tim's tool works well. That is the tool I used. I started using the air pressure to hold the valves up but switched to the TDC method. That worked so much faster and easier.
