98 rockers same as 00??
Old Feb 23, 2008 | 09:58 PM
bigti99a's Avatar
Default 98 rockers same as 00??
i have a set of 241 heads i am putting together. would rockers from a stock 98 work? what aftermarket ones would be good for a dd street car? thanks in advance to all who knows more than me!!
Old Feb 24, 2008 | 06:31 AM
deadmanTA's Avatar
They should be the same the ones from my 02 looked identical to my 99's. I like the shaft mounts myself, but I don't want to drop the $600 + for them
Old Feb 24, 2008 | 06:48 AM
SOMbitch's Avatar
You could let Harland Sharp rebuild your stockers for $225 and eliminate the needle bearing issue or spring for some Yella Terra Ultralights for about $400. You can also just run your stockers as is which is prolly what most people do.
Old Feb 24, 2008 | 09:16 AM
kwiksilverz28's Avatar
Get the stock ones rebuilt. It was $265 including shipping and new bolts from Nasty, and I had them back in less than a week. I will run these even when I go stroker down the road....
Old Feb 24, 2008 | 10:26 AM
bigti99a's Avatar
man you guys are great thanks for the info.
