Is there any differences between the ls1 and ls6 head?
Jordan
Casting Number 241
LS1 / 5.7L Passenger Car and Corvette
P/N 12559853 (97-00)
P/N 12564241 (01+)
Material: Aluminimum
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
___________________________________________
Casting Number 243
LS6 / 5.7L "ZO6" Corvette
P/N 12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
As others have said, the exhaust port design is different between the heads. The LS6 has a "D" shaped exhaust port, while the LS1 does not. Bone stock, the LS6 will certainly flow better. Once fully ported and using the same size valves, I believe they both will flow about the same. Maybe just slightly better on the LS6 heads.
Ron,
I am pretty sure that the intake and exhaust volums changed from 2000-2001/2 I am pretty sure in 01/02 they also went to 210cc I and 75cc E. the GM H/P mag I have states that any how but it would not be the first mistake a magazine has made? Just thought I'd throw my .02 in.
The LS6 has a larger "short side" runner radius than the LS1. In effect, the air entering an LS1 combustion chamber makes a sharper turn from the intake port to the valve than with an LS6 head.
My fluid dynamics professor would call this "making the air angry" by forcing it around the tighter radius.
