Why is it the 7th cylinder that breaks first most of the time
Is it just LS engine ? Just stock engine? why?
When I installed my Fast, I afro engineered a set up that connected with the front steam tubes so that coolant would circulate. I was amazed how much coolant flowed through those back steam tubes.
I think a higher flow water pump might help, but its not proven either. Best is to make sure you don't lean your tune too much as a starter.
Read the plugs after some driving. Your plugs will tell you the state of the burn going on inside.
, and another,
