Timing chain dampener?
Old Feb 25, 2008 | 11:31 AM
98-mongooSSe's Avatar
Default Timing chain dampener?
I putting a cam in my car along with an LS2 heavy duty timing chain & the LS2 dampener will not fit the LS1 block. The LS1/LS6 dampener is no longer avalible through GM as well. Any thoughts on where I could get one of if I even need to since the LS1's don't come with them to begin with?
Shay
Old Feb 25, 2008 | 02:28 PM
Russ K's Avatar
The early (beige) damper has a 2.187" bolt center spacing. SDPC had it in stock last year, but it is now discontinued.
The late (black) damper has a 1.762" bolt center spacing.
Russ Kemp
Old Feb 25, 2008 | 02:48 PM
Right, so if I don't want to drill & tap my block to get it put in, is it a big deal to run without one? This is just a street car that doesn't get any abuse, I just want to take all the precautions that I can.
Shay
Old Feb 25, 2008 | 02:52 PM
larrygto's Avatar
If you look around a few people have them or at least have them listed, But the want an arm and a leg for them!
Old Feb 25, 2008 | 04:00 PM
So if I do actually find one, is it worth spending $100 - $120 on?
Shay
Old Feb 25, 2008 | 04:04 PM
vettenuts's Avatar
I would try several vendors. I got mine from Thunder. The damper prevents the chain from wrapping on the crank sprocket at higher RPM. A lot of guys don't run them, but it does aid in timing chain life. I think its a good thing to have, but that's only my opinion. I felt the cost of a broken timing chain was high so for me the $100 was worth it.
Old Feb 25, 2008 | 07:16 PM
Russ K's Avatar
Did you measure the bolt center spacing? If your block has the wider bolt centers, the late damper bolt centers will be off the edge of the raised bosses of the block.
Russ Kemp
Old Feb 25, 2008 | 09:49 PM
Michael02hawk's Avatar
Wow, I just bought the LS6 damper for my setup last year at this time. I guess I got lucky in that they were still available then.
Tho, I did pay just over $100 for the damn thing. But I'm glad I did. Since I had an LS6 block, it bolted right in.
Old Feb 26, 2008 | 05:50 PM
blazerls1's Avatar
I just purchased the black ls2 dampner the other day from the dealer for $9..It fit on my ls6 block.I have a later ls6 block with equal length head bolts...
Old Feb 26, 2008 | 08:15 PM
JudgeGuns's Avatar
Old Jul 3, 2008 | 12:57 AM
Samba242's Avatar
Anybody know if any vendors have the LS1 version still in stock? Having a lot of trouble locating one.
Old Jul 3, 2008 | 07:53 AM
vettenuts's Avatar
As stated above, doesn't appear to be made any more. I am surprised that the aftermarket hasn't picked up on this and made one.
Old Jul 3, 2008 | 08:45 AM
Redlinez's Avatar
Thunder Racing would be the best bet.
Old Jul 3, 2008 | 08:53 AM
StevieZ's Avatar
Anyone know if there was ever one made for a double chain?
Old Jul 3, 2008 | 09:47 AM
vettenuts's Avatar
Not specifically but there are some running it with the double.
Old Jul 3, 2008 | 10:35 AM
Randy WS6's Avatar
I had the damper in my LS2 with a double roller timing chain, But when i went to change my cam ,the timing gear would drop down on the damper and would not let me remove the chain, And tried to remove the damper and the oil pump was in the way, so i had to remove the pump ,Witch is a pain in the ***. I took the damper off and left it off. Now i don't know if the problem would be with a single chain. The damper will fit with a single or double chain.
