New Cam and Spring install writeup done
Old Jul 17, 2003 | 03:16 AM
jmX's Avatar
jmX
Default New Cam and Spring install writeup done
Well, after countless cam installs and who knows how many hours of work, I finally finished up the F-body version of the cam and valvespring swap writeup.
The goods are right here:
http://www.ls1howto.com/index.php?article=23
It has a FAQ, cam basics, and photos and text of everything you've gotta do to install a cam. If some of you experienced guys have done a few of these and think there is something I should add, email or MSG me and let me know!
And hopefully I can finally get some sleep!
Old Jul 17, 2003 | 06:15 AM
Reckless's Avatar
Super Moderator
Default Re: New Cam and Spring install writeup done
Very nice! I don't think people realize how much time and effort go into a write-up such as this. I commend you for your work on this, and especially all the hard work on your install page
Old Jul 17, 2003 | 07:26 AM
finalymodded's Avatar
I love your write ups jmx LOL I used your cam install "the old one" that included your head install and had noooo probs. I just wish you could do a complete motor removal.
Old Jul 17, 2003 | 08:28 AM
NasT's Avatar
jmX Very informative love the detailed pictures..Your site eventually will be like a HAYNES manula but with Better pictures, and better explainations for normal shadetrees to understand..Thanks
Old Jul 17, 2003 | 09:30 AM
HOSS99's Avatar
jmX, Awesome write up! Thanks!! How difficult was it to get to the back valve springs using the sawed off tool?
Thanks,
Bryan
Old Jul 17, 2003 | 09:37 AM
TaTommyWS6's Avatar
ABSOLUTELY BEAUTIFUL WORK!!!
Once again, I must say, your writeups are invaluable for us "do-it-yourselfers"
Thanks!
Tommy
Old Jul 17, 2003 | 10:12 AM
Cal's Avatar
Cal
Thanks,
Bryan
I did it that way, it was real easy . . .
Old Jul 17, 2003 | 10:33 AM
Casper9T9's Avatar
Excellent write-up! I'll be using this in a week or so.
Old Jul 17, 2003 | 11:39 AM
Z-Rated's Avatar
man we cant thank you enough!!
Old Jul 17, 2003 | 11:48 AM
MOBE's Avatar
Yes, Absolutely! Great write-up!
...And what a fine specimen (car) you had to work with.
Old Jul 17, 2003 | 11:51 AM
Z-Rated's Avatar
mobe, what cam did you get ?
Old Jul 17, 2003 | 12:04 PM
MOBE's Avatar
sent ya a PM
Old Jul 17, 2003 | 12:38 PM
BLO BY U - TA's Avatar
cry-baby buyer
I will be printing this and using it for my cam install....Thanks Man
Alan
Old Jul 17, 2003 | 12:40 PM
Dave Carney's Avatar
Looks excellent! The only thing I would add is that the a/c condensor can be bungee corded to the hood latch during the r&r of the cam, for us guys that work entirely alone....
Old Jul 17, 2003 | 01:01 PM
Cal's Avatar
Cal
Good point . . . I did something simialar; bungeed mine to the passenger side quarter pannel and got it totally out of the way . . . had to rotate it 90* to do this but didn't break anything or cause any leaks, AC still works perfect. I did my cam install entirely alone also! I already emailed jmx with this but I guess he didn't like it because he didn't put it in his write up.
There are a couple of other things that I think should be added as well: get one of the extra strong 8 mm impact sockets for taking out the rocker bolts; many people break several normal sockets in doing so. Be sure to clean the threads with solvent on any bolt that you use locktite on, otherwise the locktite is useless. You can use carb cleaner or acetone to do this. Stuff a rag in the front of the oil pan before you take out the oil pump pickup tube bolt so you don't drop it in the pan. This is very easy to do.
Old Jul 17, 2003 | 01:07 PM
Cal's Avatar
Cal
Thanks,
Bryan
Oh and BTW, this tool works MUCH better if you grind the lips down right under the bend. If anyone is interested, I can post a picture. If you don't do this, you will scratch the gasket surface on you heads, not a good thing. Also makes it much easier to use a stock rocker bolt on the tool.
Old Jul 17, 2003 | 01:08 PM
CAT3's Avatar
Restricted User
Very nice detail, excellent write up. JMX you deserve the Key to the LS1 City!
Old Jul 17, 2003 | 04:42 PM
jmX's Avatar
jmX
Thanks guys!
Cal, I've used the bungee method many times before and it is fine. I didn't put them in this document because I figured most people will have a helper, but I may add it back in. I beleive I mention it in some of my other writeups. If you can take some pics of the tool I'd love it. I know exactly what you mean about grinding it, but I unfortunatly do not have one handy that I can take a photo of at the moment. I'd put the picture into the install if you could get me it. Thanks!
Old Jul 17, 2003 | 04:50 PM
Scalpel's Avatar
jMx, you da' man. That is KILLER install page, great tech info and FAQ too
Old Jul 17, 2003 | 08:55 PM
Billiumss's Avatar
That right up is the best. I plan on doing another cam swap this winter and I'll use your guide if I run into a snag.
Are you ever going to do a LS1 Edit Tuning article? I've been learning it from an ex GM tech and so far, it seems pretty easy. Just the basic would be nice explain what table does what...
