Oil dipstick pops out while driving
Old Feb 26, 2008 | 12:59 AM
HottLS1Z's Avatar
Default Oil dipstick pops out while driving
So the last few times I popped my hood to check the oil level, my dipstick is popped up against the hood like something is trying to push it out. If the car is just idleing it dont pop up but seems to be after I been driving for a while or get a heave foot, why is this happening?
Old Feb 26, 2008 | 01:03 AM
01slowbird's Avatar
car running okay?
Old Feb 26, 2008 | 01:22 AM
HottLS1Z's Avatar
running just fine, good oil preassure and everything! No change in anything.
Old Feb 26, 2008 | 01:23 AM
HottLS1Z's Avatar
could a bad PCV valve cause something like this? Only idea I have.....
Old Feb 26, 2008 | 01:29 AM
bczee's Avatar
I would also suspect the PCV system. Did you modify it or have you checked to make sure it is not plugged ?
Old Feb 26, 2008 | 02:01 AM
DONAIMIAN's Avatar
Another vote for the PCV
Old Feb 26, 2008 | 02:12 AM
dug's Avatar
dug
it happend with my old camaro to. I never bothered to figure it out. just pushed the dipstick back in. It wasnt that bad. itd just pop up an inch
Old Feb 26, 2008 | 04:40 AM
Ryan K's Avatar
Pathological Modifier
PCV system or Too much piston blowby. Could be an indication of broken ringlands/piston.
Ryan K.
Old Feb 26, 2008 | 06:28 AM
brad8266's Avatar
Clogged PCV system or worn out piston rings.
Old Feb 26, 2008 | 07:32 PM
HottLS1Z's Avatar
Whats a good way to check this?
Old Feb 26, 2008 | 08:00 PM
bczee's Avatar
with the engine running, pop th pcv tube end off of the valve cover and see if you can feel some vacuum. Try at both idle and at 1500-2000 rpm's
Next try taking the oil filler cap off and put your hand over the opening to seal it.. see if you feel vacuum or pressure at both idle and with some throttle.
Old Feb 26, 2008 | 09:34 PM
transAm-98's Avatar
I was blowing oil past my dip stick for awhile. Put a new O ring on the top of it, problem solved
Old Feb 26, 2008 | 09:36 PM
99mongooSS's Avatar
too much crankcase pressure.
Old Feb 26, 2008 | 10:03 PM
HottLS1Z's Avatar
cause and solution?
Old Feb 26, 2008 | 10:15 PM
FMX05's Avatar
Originally Posted by HottLS1Z
cause and solution?
clogged PCV system like they said up there ^^^ or rings...
Old Feb 26, 2008 | 11:33 PM
HottLS1Z's Avatar
these cars have one PCV valve right?
Old Feb 26, 2008 | 11:47 PM
fuseone's Avatar
what if it only popls the dip stick a little bit like 1/4 of a inch. becuase thats what mine does and i changed my pcv valve. and yes they only have one pcv valve
Old Feb 27, 2008 | 10:04 PM
HottLS1Z's Avatar
Ok so I changed out the PCV valve today, still doin it. No suction that I can feel or pressure out of the oil fill cap. Tried a test at idle, and throughout the RPM range all the way to like 5K. Took it for a ride for like 20 min, pulled over and the dipstick was still down. Did a WOT pass shifting at 6500-6800 rpm, pulled over checked again and it was popped up a bit again maybe an inch, still no vaccume or pressure outta the cap or the dipstick tube.
What else can I do to figure this out? Its not bloeing any smoke out of the exhaust or anything
Old Feb 27, 2008 | 10:06 PM
HottLS1Z's Avatar
I need to know if this is something serious or not, I just ordered a new set of heads and lifters etc, but dont wanna waist my time putting them on if its just gonna pop the motor soon....
Old Feb 27, 2008 | 10:28 PM
HottLS1Z's Avatar
Anyone?
