36# or 42# injectors
Old Feb 26, 2008 | 01:34 PM
badLS1ass's Avatar
Default 36# or 42# injectors
what injectors should i get since im going to be getting new heads? i was thinkin about the 42# ones in case i decide to hook the nitrous back up but would it run fine with out nitrous as long as its tuned properly? also what brand should i get?
thunder racing cam-230/236 .592/.602 112 LSA
fast intake-92mm
fast throttle body- 92mm
patriot gold valve springs
thunder racing hardened push rods
strange S60 rear end
411 gears w/ easy locker
35 spline axles
BMR springs
BMR panhard bar adjustable
BMR adjustable torque arm
txtralia clutch
upgraded flywheel
Z06 hydraulics for clutch
steel driveshaft
mti airlid
pro 50 shifter
pacesetter headers
3" y pipe w/ cut outs and slp loudmouth
nitto 555Rs
Old Feb 26, 2008 | 01:57 PM
SLP Firehawk's Avatar
i was told to step up to 42 lb injectors in case you want to mod even more ie heads in the future so that way you aren't buying them twice.
Old Feb 26, 2008 | 02:27 PM
ls1leadfoot's Avatar
always go bigger.....even though the price sucks!!
Old Feb 26, 2008 | 02:44 PM
Apollo0526's Avatar
42's :-)
Old Feb 26, 2008 | 03:14 PM
badLS1ass's Avatar
what brand??? should i get
Old Feb 26, 2008 | 03:27 PM
DONAIMIAN's Avatar
36's are more than enough, but get whatever is cheaper.
Old Feb 27, 2008 | 07:55 PM
02TransAm/Batmobile's Avatar
Dude, you gotta be shitting me. This is your 3rd thread on the same exact subject. I'll say it one more time:
36 for your application, 42's if you add on the nitrous.
Old Feb 27, 2008 | 08:00 PM
kwiksilverz28's Avatar
Racetronix 42#.
Old Feb 27, 2008 | 10:21 PM
badLS1ass's Avatar
where can you get racetronics? and what do you all think about fast 42#?
Old Feb 28, 2008 | 11:56 AM
The cheapest place I found 42 injectors are via Harris Speed Works.
Old Feb 28, 2008 | 12:25 PM
fast377's Avatar
42s...just in case you want to do more mods later.
