How bent is a bent pushrod
Old Mar 1, 2008 | 01:51 PM
mvvette97's Avatar
Make a video of it so we can hear it. It may not be a knock
Old Mar 5, 2008 | 10:25 PM
shanezz's Avatar
We are 90% sure its a piece of carbon we are trying to dissolve it before I pull the head.
I know it is rare but it is exactly at top dead center of #8 & 5. Anyone have any ideas?
Old Mar 5, 2008 | 11:02 PM
Quickshift_C5's Avatar
I'd like to hear more about pulling the spark plugs or the wires to check which cylinder the ticking/knock is coming from. I haven't heard of this before.
So which is it, pull the actual spark plugs or only pull the wires from the plugs? What will this do exactly?
Old Mar 6, 2008 | 04:27 PM
shanezz's Avatar
Pull the wire to keep it from combusting & it should change the pressure on that rod knockwhich should change the pitch.It did not change in my case.The heads are coming off, I give up on the piece of carbon theory.
Old Mar 6, 2008 | 04:59 PM
ssduane's Avatar
Have you checked to see if the torque convertor bolts are tight. I've had some come loose and it sounds like a rod knock also.
Also, have you tried pinpointing the area with a mechanics stethascope.
Old Mar 7, 2008 | 07:15 PM
shanezz's Avatar
Well, the motor is out of car with a bent crankshaft. It must of happened when the car was in accident.The motor looks like it couldn,t have more than 10K mi. on it.
Old Mar 7, 2008 | 07:24 PM
SOMbitch's Avatar
Bummer. Sorry!!!
Old Mar 7, 2008 | 07:27 PM
Ah man, that blows. Sorry!
I'm scared to death to start checking my motor out, I know something is bad in it. I have no experience in doing such a thing and don't have the room for it. I wouldn't even know where to begin.
Old Mar 9, 2008 | 08:09 PM
CalSpeedPerformance's Avatar
For the cost every ls1 should get a set of moly pushrods..its just a good idea.
