Texas Speed Torquer v.2 Camshaft
Old Feb 28, 2008 | 12:30 PM
sl99ls1's Avatar
Default Texas Speed Torquer v.2 Camshaft
i was thinking of buying one for my 99 z28 has any put one in there car and do i have to change my lifters and push rods and how much power some i be putting to the wheels
Old Feb 28, 2008 | 12:50 PM
Demon Of Dreams's Avatar
I run one with hardened pushrods but stock lifters... no problems so far
Old Feb 28, 2008 | 12:56 PM
sl99ls1's Avatar
how much power did you put to the wheels????
Old Feb 28, 2008 | 12:57 PM
410ish on stock heades/intake and no pulley
Old Feb 28, 2008 | 01:30 PM
sl99ls1's Avatar
and what is the Lobe Seperation mean ?
Old Feb 28, 2008 | 01:47 PM
01CamaroZ28's Avatar
hate to be a dick but its in the stickies
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old Feb 28, 2008 | 01:48 PM
slt200mph's Avatar
NO botton end but good from 4000 rpm-7000 rpm..ran one for 40,000 miles
Old Feb 28, 2008 | 02:02 PM
sl99ls1's Avatar
what should i get after my cam swap???
Old Feb 28, 2008 | 02:13 PM
transamfreak01's Avatar
try a search on this cam. theres been a 100 threads about this cam and the stickies will help you to get a better understanding
Old Feb 28, 2008 | 02:36 PM
acidburn's Avatar
Dont kno if u have but i highly recommend getting sum springs.... If u still have ur ls1 intake u might want 2 look into getting an ls6. I pretty much have ur same setup and it put out 391... prob would have hit the 400 mark if it wasnt 4 the intake holding me back.... go 2 http://www.ls1howto.com/index.php?article=23 and it will give u a list of parts needed... will u be doing it urself?
Old Feb 28, 2008 | 02:46 PM
LSGunZ28's Avatar
i dont think he will make 410, unless he had A PULLEY AND LS6 INTAKE IF HE HAS NO HEADS... and if he is a m6 as well...
Old Feb 28, 2008 | 03:11 PM
slt200mph's Avatar
I made 416 rwhp with stock heads, LS6 intake, headers, no underdrive pulley, no cats, and through the cat back..if you are running a six speed 4.10 gears are needed.I ran it for about 40,000 miles.
Old Feb 28, 2008 | 04:02 PM
2000KnightRider's Avatar
See info in my sig
Old Feb 28, 2008 | 05:24 PM
dkbykesdk's Avatar
ms4 cam!
Old Feb 29, 2008 | 01:15 PM
sl99ls1's Avatar
well im going to buy the cam today vut what Lobe Seperation do i get ??
all i have is a m6 with pacesetter lt's and a bolra catback
Old Feb 29, 2008 | 01:28 PM
brad8266's Avatar
I have a cam very close to a Torquer but a little smaller and a set of heads, made 452/415. Makes 385ft lbs @ 3500rpm's
Old Feb 29, 2008 | 01:39 PM
stealthy_2005's Avatar
Lobe seperation (LSA) is how well it idles, the lower the number, the choppier it idles... the higher the number the more calm or "stock like" it will idle
Old Feb 29, 2008 | 01:44 PM
sl99ls1's Avatar
what do you think is the best for a daily driver
Old Feb 29, 2008 | 01:46 PM
brad8266's Avatar
That is a very inaccurate and misleading statement. LSA has much more to do than that.
Old Feb 29, 2008 | 01:51 PM
sl99ls1's Avatar
what would you say about it and what do you think is the best for a daily driver
