New Sponsor! Trick Flow
Old Feb 28, 2008 | 08:40 PM
Bhogan909's Avatar
The flow numbers he posted were from the 215cc "As-Cast", meaning that they're not CNC ported. They have the same program ran through the casting process that the CNC 215 version has. They have a "cast" intake and exhaust runner and a CNC ported chamber.
Old Feb 28, 2008 | 08:54 PM
MPM IV's Avatar
Welcome! Always good to have manufacturers available to provide insight about there product. You're heads work pretty well IMO.
Old Feb 28, 2008 | 09:01 PM
99mongooSS's Avatar
awesome Im looking at a set of trick flows right now.
Old Feb 28, 2008 | 09:19 PM
ss1's Avatar
ss1
Actually, both the LS1 and LS2 "As Cast" TFS heads have 220cc intake runners, not 215cc.
Aside from that, you like the heads? Have any pics you could share with the rest of us?
Old Feb 28, 2008 | 09:30 PM
Midnight02's Avatar
Welcome guys. I'm loving my TFS cam.
Old Feb 28, 2008 | 09:31 PM
Bhogan909's Avatar
ss1 that is correct, however that's how they are advertised so that's how I believe is best to inform everyone. AFR 225's actually have 229cc intake runners. It's just posting exactly what the manufacturer advertises.
Old Feb 28, 2008 | 09:37 PM
ls2 bait's Avatar
i have them and love them. mine are the cnc versions. i heard rumor that maybe an intake manifold would be coming out? any truth to this? also will tfs be making a pedastal to use stock rocker arms in the future? i have harlands now but id rather run the stockers.
Old Feb 28, 2008 | 10:16 PM
m8w6r77's Avatar
i seen there something about a spacer for the vavle cover if you are running the shafted roller rockerss. is that certain camshafts you have to run them or is that on all of them?
Old Feb 29, 2008 | 01:42 AM
getusum's Avatar
I'm running the 225's 65 cc......I absolutely love these heads...Thanks to Brian Tooley @ TEA for bringing Trickflow to us before You actually became a sponsor......My heads flowed better than advertised as well, LME has them at 343 cfm @ 600 on their flow bench
Old Feb 29, 2008 | 07:52 AM
ss1's Avatar
ss1
Brian, I believe the confusion may be from Vengeance advertising them as 215cc before anybody else was really selling them. Trickflow and others are all listing them as 220cc now.
http://www.trickflow.com/egnsearch.a...1&autoview=sku
http://weberracing.net/Engine-Type-G...duct_info.html
Edit for clarification: These are links to the "As Cast 220cc heads"
Old Feb 29, 2008 | 08:06 AM
bluecamaroz28's Avatar
Welcome to LS1Tech.
I have their TEA cnc'ed 64cc TFS215's and flow number are higher than posted, 319.5/262.7 @0.600" lift.
ss1, you are refering to different heads. Here's the link for TFS215:
http://www.trickflow.com/partdetail....1&autoview=sku
Question for Trick Flow team, what's the max bore, ci that TFS 215 should be run as is w/64cc?
Old Feb 29, 2008 | 08:34 AM
  #32
ss1's Avatar
ss1
Yep, I know the difference. The reason I posted that was to show that ALL of the "As Cast" heads are 220cc, while the CNC'd heads are 215cc, 225cc, and 235cc.
Old Feb 29, 2008 | 08:48 AM
  #33
turbogarrett's Avatar
I will check the cc of the runners on the cast heads and post pics when I get them next week. I ordered them thinking they were 215, but doubt the 5cc difference will affect much, hope not anyway. Coming from 230 runner truck heads I doubt I'll be disappointed
Old Feb 29, 2008 | 09:10 AM
  #34
TrickFlowTech's Avatar
LS1Tech Sponsor
Originally Posted by vettenuts
I have a pushrod question for TFS.
I believe the TFS heads use a little bit longer pushrod. I have also read that Spintron testing has been showing the 5/16" pushrods (any head) have quite a bit of flex (several test sites have reported this). Has TFS ever considered fabricating an LSx specific tapered pushrod in lengths say from 7.300" to 7.500" (0.025 increments) that would help minimize the pushrod deflection yet still fit within the stock head without machining?
PS: Welcome as a sponsor.
Thanks for the welcome.
At this point we have not done any testing on this.
Old Feb 29, 2008 | 09:11 AM
  #35
LS1Tech Sponsor
Originally Posted by odarabla
Is this the 215cc cnc ported heads? I did find one site that said they flowed 320cfm @.600 lift and 306 at .500 lift. Was this wrong?
The numbers I posted are the numbers for the As Cast heads not the CNC'd heads.
Old Feb 29, 2008 | 09:20 AM
  #36
LS1Tech Sponsor
The rumor of the intake coming out is just that .... a rumor. Not saying we haven't looked into it but nothing is in process.
As of right now I do not see a pedastal head coming out in any near future.
Old Feb 29, 2008 | 09:33 AM
  #37
LS1Tech Sponsor
Originally Posted by bluecamaroz28
Welcome to LS1Tech.
The best application for the 215 head is the 3.90 bore, although we have had customers run them on the larger bores with great success.
Old Feb 29, 2008 | 10:01 AM
  #38
LS1Tech Sponsor
Just like anything else in building a motor, you need to check your clearances. In some cases they may clear no problem, in others you may get a way with clearancing the valve cover or running the spacer. We like to see .080" - .100" clearance between the rocker and the valve cover just to be safe.
Old Feb 29, 2008 | 02:18 PM
  #39
m8w6r77's Avatar
okay. thank you very much. i am going to be running the package 515hp/460 ft lbs. can't wait.
Old Feb 29, 2008 | 03:58 PM
  #40
Viper's Avatar
"515hp/460 ft lbs." flywheel right?
