oil pump help
Old Feb 28, 2008 | 04:59 PM
98mysticZ's Avatar
Default oil pump help
ok so i bought a ported/shimmed ls6 oil pump from texas speed a while ago about 10k and i am now putting together a 408 (spun a rod bearing) if i pull the pump apart and clean it all out check for scaring and there is none i should be good to reuse it correct? the rod bearing went and was shut off at 1st noise when i tured it off it still had oil pressure.. what should i do i dont wanna have to spend the money on a new one if i dont have to
Old Feb 28, 2008 | 05:44 PM
ROCNDAV's Avatar
yeah should be good. Don't forget to pull out the relief valve (the shim, spring and piston) and make sure that area is all cleaned out.
