Can someone check under their hood for me?
I would really appreciate it! If you pop the hood and look to the right side of the frame there is a small black wire to the frame with a 10mm bolt. There is also a ground strap somewhere. Is the ground strap also with this bolt, and grounding to the engine? Againe, I would really really appreciate if someone would check that would be f**kin sweet
There sould be one going to the block and the frame. On my car it looked like a flat braided copper wire and I think that there was also one running from my alt to the frame. car was bought used, and I know the old owner did some things to the wiring so I am not sure if the alt wire was stock or not though
