Weird OEM valve cover ?
Basically he didn't know what he was talking about.
1. After 3 different techs gave me the same answer use the new cover and plug the hose.
2. Get a machine shop to remove the tube from the old cover and weld it to the new cover.
3. Use the new cover and get a breather like the ones that plug into the oil filler neck or a catch can with a breather?
Im gonna have to do something because the cover thats on the car now has 3 small cracks around the oil filler neck and it just a matter of time before it lets go. So whats up guys what should I do here?
"Hello, I am pretty sure you have been given the right info from your tech. the orginal valve cover has a port for the pcv hose that runs over to the left valve cover. the replacement valve cover does not have this port. but dont worry the engine will still vent pressure thru the left valve cover and pcv."
At first I was thinking these people are crazy but sofar every person ive asked has given the same answer???????
As Connexion2005 explained, a proper PCV system needs a fresh air source to "flush" the moisture, harmful corrosive vapors, un-burn't fuel, and combustion gasses from blow by (even a perfectly sealed ring set will allow some blowby past....just not much). Now the crankcase pressure built up is released as long as the system is not disabled (plugged off), but you need a vacuum source to draw those vapors out at idle & low RPM. This comes from the intake manifold on a NA motor, and can come from the induction in front of the turbos/supercharger (as pressure is built up in the intake & will pressure back through where it should have been sucking) . This vacuum source needs a device to meter or limit the amount of vacuum so the PCV valve is used on the early GenIII & a fixed orfice in the valley cover on the later GenIII & GenIV. If the drivers side fitting is capped off then there is not a full even flow through the entire crankcase & internal engine in general. It will still pull from the pass side , but does not give the fresh air a complete route through the crankcase. The fresh air in the OEM setup is drawn from the front fitting on the throttle body so it is filtered by the main air filter. (Never have an unfiltered line open to the crank case EVER...your motor will loose 1/2 or more of its life due to all the dust/dirt/sand/moisture/ and who knows what else into the crankcase and slowly grind the internal parts to death) So, idealy you want a vac source that is metered or controlled
and them a good functioning catch can to seperate, trap, and condense the vapors as well as the oil mist that most cans trap (the bigger the better), an equal outlet setup to draw the vapors & gasses out, (either the valve covers in the rear or as in the later GenIII's, the valley cover) and a filtered frsh air source that can be the stock OEM tube to the TB frnt, or a filtered breather.
Here are more pics & info from another thread that addresses a very ALARMING modification that some one is doing all over the place & is drawing dirt & dust directly into the internal engine:
Heres the problem with hoses hanging near the ground & plugging your vacuum source. When at speed, one hose will develop negative pressure, and the other positive as the hose has a venturi effect when air is moving past it. What happens then is you are sucking up dirt, sand, water, etc. directly into your valve cover & into the motor internals. I suspect they have no filter on them, correct? Also, if you are not pulling metered vacuum at idle & low RPM's the harmfull vapors that are in your crankcase cannot be pulled totally out...only pressure vents so all the unburnt fuel, caustic gasses from blow-by, & moisture will re-condense in your crankcase after the motor cools & contaminate the oil as well as corode internal parts (look at the links in another thread on bearings & see the damage just the unfiltered dust causes). A proper PCV system needs a fresh air source that is filtered, (on the stock OEM setup it is drawn from in front of the throttle body & the main air filer cleans the air pulled) and a vacum source that is metered & valved, such as the PCV valve on a LS1 or the fixed orfice & baffle system in the vally cover of the LS6 & LS2/3/7 design. The problem with the OEM systems on our vettes is it allows oil vapors to be pulled into the intake & robs power & contributes to detonation. The only proper way to correct this w/out sacrificing your engine to premature wear (I have seen motor come in that look like dirt was poured right into the crankcase & no internal part not showing advanced wear & failure from the hoses dangling unfiltered to the ground. Those that have this setup just have to look closly at your oil the next time you change it to see how dark it now comes out compared to when you had the stock system in place) is to modify the system to remove as much of the oil & harmful vapors from the PCV lines before the mist is pulled into the intake. So the most effective mod for NA motors is to add the proper catch can system AND a PCV valve inline to control the amount of vacum pulled & prevent back-flow of the vapors.
The catch can must be of a material that disipates heat effectively, and that eliminates plastic. Auminum or steel are the 2 best. 2nd, the can must be baffeled in such a way as it disperses the vapors to make contact with as much of the cooler outer surface of the can to allow the vapors & oil to condense into droplets that are collected in the bottom of the can. Now 2 forms of oil come through the system....a mist from the fast movong internals in the engine which is pretty easy to trap, and the vapors from the high heat which need the cooler surface area to condense.
So the can has to be large enough to be effective & most I see in use are far to small, allthough there are several good ones on the market. Then the outlet of the can must be located as far up & away from the inlet to prevent vapors from being pulled through before having a chance to cool & condense. You then need a PCV valve to control the amount of vacuum.
(this setup uses a perforated down tube to disperse the vapors as completly as possible for contact on the cooler surface & is a 1 qt capacity)
If you have a stroker, big cube build, or run at extended high RPMs you should also add the filtered breather as some have mentioned above (easiest is as an oil fill cap mod) and this will allow a good volume of filtered fresh air in at low RPMs and allow venting of crancase pressure at high RPMs. On a FI application it gets just a little more complicated but the design is very similar.
Shown below is on a Magnacharger application.
So what you have accomplished is a near total elimination of any oil getting into the intake, proper ventalation & breathing, and not subjecting your babies motor to a slow horrible premature death from unfiltered ventalation.
Hope this helps, anyone wanting any clarification dont hesitate to contact be.:thumbsup:
