LS7 Lifter pre-load
Old Mar 9, 2008 | 04:26 AM
HottLS1Z's Avatar
Default LS7 Lifter pre-load
Ok so , I have been reading the lifter failure stories lately and just to verify everything before I do my lifter swap next week, I got the LS7 lifters which are now the replacement for LS1 stock lifters from GM correct? Also what is the suggested pre-load for these lifters? I have stock length chromoly pushrods too this is ok with these lifters for a H/C pkg right?
Old Mar 9, 2008 | 10:27 AM
oange ss's Avatar
someone posted they're .060 taller than stock ones, i think that has more to do with the failure than the preload...
Old Mar 9, 2008 | 05:02 PM
HottLS1Z's Avatar
Anyone else used these?
Old Mar 10, 2008 | 12:37 AM
HottLS1Z's Avatar
So can anyone tell me will my stock length push rods going to work with these lifters and are they different or not? Is the pre load supposed to be different then the stock origional design?
Old Mar 10, 2008 | 05:41 PM
little Red Camaro's Avatar
I just replaced my old stock lifters with the LS7 this weekend, and no problems. All I did was soak them overnight in oil and dropped them in the next day. I am running VRX5 cam, 7.400 comp rods....working great so far!
Old Mar 11, 2008 | 09:13 AM
HottLS1Z's Avatar
The fact that I'm swapping out stock heads for TSP stg 2.5 5.3 heads shouldnt make a difference either should it with pushrod size and these lifters?
Old Mar 11, 2008 | 10:26 AM
PREDATOR-Z's Avatar
They take the same preload as previous stockers (otherwise they wouldn't be a direct replacement )
Old Mar 11, 2008 | 04:08 PM
01Z0H6's Avatar
I too am running these with my G5X3 and the 7.4 p/r... Have already put about 37K on them.. Still working just fine..
Good luck!
