High oil pressure problem!!
i've run GC 0w30 for over a year now with wix filters, and last time i checked my oil it still looked brown with 2-3k miles on it. it's not time to change it yet, and i've used these filters before so i'm sure the filter isnt clogged. the oil is also leaking out of the front of the engine around the timing cover and oil pump area, under the water pump. i'm adding a quart of oil every 1000 miles or so. pretty significant leak.
so where do i need to start checking?
I use M1 0w-40 and mine runs about the same but at WOT the oil pressue guage pegs out
Second, synthetic oil should only be slightly brown at 3k miles but still somewhat golden if you completely drain the oil pan at change time.
As for the oil leaking thats an entirely differant problem probably from a torn or worn out gasket, but without really looking at it Im just kind of throwing ideas out there
now that i think about it, could a clogged filter cause this? or a clogged pcv system?
I'm about to go to 0W40 from 5W30, so I am curious what I am going to see.
