? about 5.3L heads?
Old Jul 22, 2003 | 09:50 AM
mykdiver's Avatar
Default ? about 5.3L heads?
If used unported with stock valves is there an increase in performance over stock LS1 heads due to the increased compression, or does the less flow out weigh the increase?
What do the stock 5.3L heads flow?
Old Jul 22, 2003 | 11:49 AM
TVWilkes's Avatar
Default Re: ? about 5.3L heads?
Stock 5.7 vs Stock 5.3,I would not do it, unless you open unthe intake valve to the same as the 5.7.
