Should I do rod bolts?
Old Mar 14, 2008 | 12:30 AM
chuckyt1's Avatar
Default Should I do rod bolts?
I'm swapping the K Member and need to replace the oil pan gasket. I was going to put in new rod bolts while I had the pan off. As most of you know ktech's are on back order so that leaves ARP's. The motor is an 02 with 18k on the clock and I shift it at 6900. Limiter is set at 7200.
Let me know what you all think, keep the stock '02 bolts or go with ARP? Anyone spinning an '02 like this? Any problems?
Old Mar 14, 2008 | 07:02 AM
black01_WS6's Avatar
I would use the ARP studs. They will give you a more room to grow in the future.
Old Mar 14, 2008 | 07:51 AM
Fratsit's Avatar
If you have the time and the money, I would do it. Especially in the range that you shift at. The little bit of time and money you spend now, could save you big in the future.
R/
Frat
Old Mar 14, 2008 | 08:01 AM
brad8266's Avatar
Studs in place of rod bolts??
Old Mar 14, 2008 | 08:35 AM
98RedBird's Avatar
I'm sure you'll hear it from someone so I'll go first. If you do the ARP's you'll need to get the big end of the rod checked. They are not the same weight as the Katechs and are not meant to be used as a simple swap and go. The Katechs are meant to be a direct replacement for stock, the ARP's are not. Some people have success just swapping them in and chancing it. Some people don't. However, if it was my motor and my money, I would get it checked for peace of mind. Your call.
Old Mar 14, 2008 | 08:36 AM
tillery's Avatar
SDPC carries them too. I got mine from them when Katech was out.
Old Mar 14, 2008 | 10:00 AM
chuckyt1's Avatar
Time is not a factor and money is not really a problem, ( I know, just buy a shortblock... ). I just don't want to waste either one of them. Also, if I had a pre 2000, I'd put in the ARP's without resizing the rod end but, don't want to chance that with the already upgraded '02.
Anyone use these? http://www.lingenfelter.com/store/2-000040rev-nc.html
Old Mar 14, 2008 | 10:16 AM
sorry I was thinking of head studs.
 Michael S. Palmer
Old Mar 14, 2008 | 12:21 PM
slowec's Avatar
Get the rod checked for what. You are swapping a bolt for a bolt. What goes wrong. Sorry to highjack but someone needs to clarify this issue.
Old Mar 14, 2008 | 05:35 PM
chuckyt1's Avatar
As far as I know, it's because when you change rod bolts, you can change the "roundness" of the big end of the rod. ARP says to resize, (check for true and size), the big end of the rod when you use their bolts.
