Car will not start (MS4)
Old Mar 14, 2008 | 02:07 PM
o-ss-kar's Avatar
Default Car will not start (MS4)
Hi.
Just wanted to ask, the first 6-7 times the car started and hardly idle´d but it did after a few mins.
But after those times it dint, just not a chance in the world.
Btw I have never driven it untuned, just in and out of the garage.
When i try to start the car, it does not give any spark.
I installed a new (tuned)PCM few mins ago but it was the same.
I have not installed the new wires and plugs yet, but i just wanted to ask and make sure if you have any advice for me if there´s something missing ?
Thanks in advance
Old Mar 14, 2008 | 02:11 PM
bjamick's Avatar
Hmm if it has been tuned for sure then if its not cranking then its the usualy reasons why no car would crank.. Fuel or spark.. If you say its not firing then you need to make sure your coils are good and also check your plugs.
Old Mar 14, 2008 | 02:21 PM
Thewhitebeast's Avatar
Did you check all your fuses? This happen to me once and I had a blown fuse. I dont remember which one it was anymore. I just remeber it was not labled as an ignition fuse..maybe pcm
